anybody try shorty headers - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 03-01-2013, 04:46 PM Thread Starter
Anybody here have any sucess with an aftermarket header for the 5.4 f150 4x4 supercab? i need to change the passenger side manifold (leaking) and know it is a fairly easy fix but am thinking about a set of headers if I am in there anyway......
Papa Paramedic is offline
post #2 of 6 (permalink) Old 03-01-2013, 04:59 PM
Manford's Avatar
Ford should have a TSB out for the right side manifold but they don't. Don't waste your time with shorties unless you like the look. You won't see significant performance gains and you still have to go through all the work. If you do decided to pull the manifold off and replace the gasket, stay with OEM Ford gaskets and before you re-install, you need to flat grind the manifold. I believe Ford has a defect that causes the firewall outlet to warp. Put a straight edge along the cleaned mating faces and you will probably find that the first 3 ports are relatively flat and then the front portion of the rear exhaust port is about 1/8" low. It took me 2 hours of flat filing to get the rear exhaust port re-aligned with the other surfaces.
Taking the manifold to a machine shop would be alot simpler but I am a cheap ass
You can get at all of the manifold bolts if you pull the tire off and have a series of extensions and swivle joints at your disposal. Before you start, spray all the manifold bolts with WD-40 the day before you start, but don't drive the truck or you will just evaporate all the fluid.
__________
ManFord
Manford is offline
post #3 of 6 (permalink) Old 03-01-2013, 05:57 PM
i wouldnt do shorties either. not worth the effort for the gain. get some longtube headers.
I used obx which is a very good knockoff of a very good product already.
http://www.sparktecmotorsports.com/h10792s.html
as sayed above. you will need the ford oem gaskets as they are the best. i used locking header bolts. i did it all in my garage and it was failry easy.
then i drove it to the exhaust shop for them to connect it to my magnaflow.
it was like a nascar thou with straight headers driving to the shop.
Many many lightning guys running the obx with no problemos. i have had mine for 3 years in the west weather and they still look great.
post #4 of 6 (permalink) Old 03-01-2013, 06:12 PM
^^^ Besr price I've seen for 04-08 4x4 OBX Headers ^^^
Thanks for the link.
Defo go for the full length headers.
Bet the HD at least sounded fast. It's a start.
2008 F150 FX4 SCAB : BLUE STREAK
She's gone but never forgotten! Replaced with a blown:
2008 F150 FX4 SCREW : SILVER BULLET
Ross is offline
post #5 of 6 (permalink) Old 03-01-2013, 08:58 PM
if you google sprakteck coupon code you can usually find free shipping or 10 off
EDIT: i did the work for you put retailmenot in the coupon area for $10 off
post #6 of 6 (permalink) Old 03-02-2013, 10:31 AM
Manford's Avatar
Stage8 locking bolts are what I used on my stang and they are the best I have seen, that being said, they are the only ones I have seen up close
__________
ManFord
Manford is offline
headers ? Cort F-150 2004 to 2008 Forum 9 07-18-2011 06:45 AM
BBk shorty headers what year Jensen Intake, Exhaust 2 04-28-2010 12:29 AM
4.0L headers? canadian.bacon Ranger Forum 5 01-27-2009 07:17 PM
I Need Help, Looking For Headers Disposable-Hero F-150 Pre-1997 Forum 6 01-29-2008 11:19 PM
