2003 Super Crew 4x2, 5.4L .... - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 04-30-2013, 02:28 PM Thread Starter
luvf150's Avatar
Exclamation 2003 Super Crew 4x2, 5.4L ....
Folks...test drove a 03 super crew, has 330k Kms, kn intake, was quite responsive and smooth. Rear shocks are shot. While driving I feel some knurling or grinding (Donna what to call it)feel on my foot while pressing gas pedal.. Is it normal? Otherwise truck seem to be ok, door bottom has been worked upon. Thanks
luvf150 is offline
post #2 of 6 (permalink) Old 04-30-2013, 03:28 PM
welcome. good luck with the vibrating pedal, dont let your wife sit on the floor anymore.
post #3 of 6 (permalink) Old 04-30-2013, 06:57 PM
I like Fords Too's Avatar
my 01 had that grind-ie feeling in the gas peddel too
I forgot all about it - though I have no idea what made it stop doing that
a year and a bit back , I had a coil replaced - the mechanic came out to the waiting area to try to sell me the "fuel injection service" 'cause "ford recomends it now"
(thought to myself ah-ha , this is why my father was paying over 4 hun everytime he got a coil replaced)
possiable the mechanic lubed the cables or throttle body ??
from new this 01 has had a hunger for coils - the coil on plug type , my 95 mercurey with a 4.6 and coil packs never needed more than a battery & alternator
5.4 2 valve motors have a habbit of blowing out spark plugs ... spark plugs in 3 valve motors break when trying to remove them
so , this in mind ^ , instead of trying to beat the price down if you want that truck - I'd ask for a brand new set of coils and a set of installed spark plugs
spark plug thread fix was 3 hun , + 5 hun to install 7 other plugs ..... and whatever coils are worth ...
I'm far from impressed with this ... so much so that I'd say if the seller is a dealer and won't change out the plugs and coils , walk away , and don't go back 'cause somebody's gonna have to replace them and it's much better if it's not you , doing them 1 at a time as they fail
thinking now , if I were doing that ^ I'd take the truck for 1 more test drive - just so I could go and mark a couple of the coils - towards the back of the motor
that way I can tell at a glance if they changed them ...before I pay for it
I like Fords Too is offline
post #4 of 6 (permalink) Old 04-30-2013, 08:29 PM
just keep an eye on the plugs and tighten if needed if now and then. and you can hear a ticking for a little bit before the blowout. but i wouldnt worry about it. the amount of plug blow outs is small. the lightning guys every now and they have one. and we are pushing the motors a hell of a lot harder then you n/a guys.
post #5 of 6 (permalink) Old 05-12-2013, 01:29 PM Thread Starter
luvf150's Avatar
Have bought the same one...it was a priv.buy ..cleaned the KN filter reoiled & the grind feeling at gas pedal is gone...so guess it was due to clogged intake..other thing I did was added sea foam to the full tank..that hopefully will clean the fuel injectors. Which one is the vacuum line on the intake. Would like to run some seafoam there too. Enjoying the rig so far. Am lookin for some used good rear shocks too.
luvf150 is offline
post #6 of 6 (permalink) Old 05-12-2013, 09:21 PM
Hey " luvf150 " try hitting up blackstock ford for your rear shocks, as they keep all the parts from trucks when they lift or lower them, not sure if you posted any pics of your truck but please do so when you have time.
2009 super crew rear springs wrangler F-150 2009 to 2014 Forum 2 03-31-2013 01:19 AM
Snow plow on a 2010 super crew Dix01 F-150 2009 to 2014 Forum 4 02-20-2011 12:14 AM
Super Crew Pulls to the Right dbgent F-150 1997 to 2003 /04 Heritage Forum 2 12-24-2010 04:37 PM
FOR SALE! 2006 Ford F-150 Super Crew greg86 F-150 2004 to 2008 Forum 1 06-13-2010 08:50 PM
'09 FX4 super crew side steps Tobermoron F-150 2009 to 2014 Forum 3 05-07-2009 05:07 PM
