1999 f150 firing just on 4 cylinders.. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 14 (permalink) Old 07-03-2013, 04:49 PM Thread Starter
volvering's Avatar
Hello to all, I hope that you are well, I am well but am in full transformation of the house this hard but great.
I post for a friend who have a 99 f150 5.4L 4x4 and he has some engine problem. The engine starts but run only on 4 cylinders.
Cylinders 1,2,3,7 are well but 4,5,6,8 make none glisten. Apparently the carburation is good.
They changed the complete plait of ignition, 8 spark plugs, 8 ignition coil, sensor of camshaft and brace but nothing makes for it.
Would have you an idea for helping my dear friend..unfortunately he don't speak english...
volvering is offline
post #2 of 14 (permalink) Old 07-03-2013, 05:28 PM
First question have you scanned this for codes?
post #3 of 14 (permalink) Old 07-04-2013, 02:15 AM Thread Starter
volvering's Avatar
hello,
i wan't the code..
just one question, do you have a reader code at your home? where are you buy it?
post #4 of 14 (permalink) Old 07-04-2013, 03:53 AM
most autoparts stores either have them or can get them for you
post #5 of 14 (permalink) Old 07-04-2013, 05:17 AM Thread Starter
volvering's Avatar
yes but i lived in belgium and it can be a lot of difference in the obd ?
one friend give me this obd scan and when i used it the scanner wrote the default code of my ford and after it wrote "complete scan is not possible" for you it's normal.
I wan't to buy one for me but i don't wan't to buy a bad scanner...
post #6 of 14 (permalink) Old 07-04-2013, 05:33 AM Thread Starter
volvering's Avatar
my friend call me and the code is for misfire cyl 4-5-6-8 and scan not completed...just that...
post #7 of 14 (permalink) Old 07-04-2013, 01:23 PM
you nees an OBD2 code reader, 96 and later is OBD2. 95 and older is OBD1
post #8 of 14 (permalink) Old 07-05-2013, 08:57 AM Thread Starter
volvering's Avatar
hello,
No one have an idea for my friend.
@taisa899: yes we have test 2 scan in obd2 and it's not possible to scan completely the ford.
I don't no why when you using your scan do you have the same problem?
post #9 of 14 (permalink) Old 07-08-2013, 02:57 AM Thread Starter
volvering's Avatar
hello all,
the problem of my friend is resolved.this is the computer unit of the ford defect.
We check with an others and the truck run like new..
see you....
post #10 of 14 (permalink) Old 11-04-2013, 02:55 AM Thread Starter
volvering's Avatar
hello all how are you?
i come back to you for my friend his F150 have a new computer in it but now the key will not run with the new computer...not good....
how to fix it....
thank's....
1999 F150 new battery not holding charge relaychatter F-150 1997 to 2003 /04 Heritage Forum 3 12-23-2009 06:15 AM
1999 F150 won't engage in 4 wheel drive ChrisB Driveline and Transmission 3 03-27-2009 04:06 PM
1999 ranger sas lonerangerxlt Ranger Forum 5 12-15-2008 06:39 AM
V6 and 4.6 and 5.4 V8 firing order fordtough.ca Sticky Tech/How to Section 0 01-14-2008 10:05 PM
Ford Engines Firing Order fordtough.ca Sticky Tech/How to Section 0 01-02-2008 01:45 AM
