P0401-P0171-P0174 default code on my 98 f150 5.4l - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 28 (permalink) Old 12-27-2013, 12:48 PM Thread Starter
volvering's Avatar
hello all,
today my wife come back of work whith the ford and have some trouble,the engine don't run good.
i put my ass in it i starded engine and it run good after 30 seconds the engine don't run good like one or a lot of the cylinder misfire....
i put my obd code reader in it and he gave's me
P0401 Egr flow insufficient
P0171 System too lean bank 1
P0172 system too lean Bank 2
for it's a problem with bensine?? i'm not sure of that...
What i'm looking for in first ? EGR or others?
it's not very easy for me to explan it.....
volvering...
volvering is offline
post #2 of 28 (permalink) Old 12-27-2013, 01:08 PM
vacuum leak?
post #3 of 28 (permalink) Old 12-27-2013, 03:08 PM Thread Starter
volvering's Avatar
Originally Posted by BlairTruck View Post
vacuum leak?
i don't know here it's night ...i fix it tomorow morning...
if no vaccum leak what are looking for after vaccum leak ?
post #4 of 28 (permalink) Old 12-28-2013, 01:08 PM Thread Starter
volvering's Avatar
hello all,
i'll check vaccum leak with a brake cleaner and the engine react when i spray on the rear of trottle body..tomorow i go to fix it...
but not easy when the engine is cold he run great....
post #5 of 28 (permalink) Old 12-29-2013, 06:36 AM Thread Starter
volvering's Avatar
hello all,
Now i look for fix a vaccum leak....and no leak nad no error code on obd..that's crazy.
Since I have my truck the rpm is around 1000 rpm and move to 1200 itself...
and now the rpm down to 700 rpm (sound good but not normal?)
What do you think about it..because my wife need the truck for working..and i don't know if it's good for the truck.
In drive the engine run like good....but now i don't know how is good or not....
post #6 of 28 (permalink) Old 12-29-2013, 07:47 AM
That's about what it should be. It should start high, about 1000~1200 rpm, then drop to 700 rpm after about half a minute. If it runs smooth while driving, then it sounds like you've fixed it.
post #7 of 28 (permalink) Old 12-29-2013, 09:08 PM Thread Starter
volvering's Avatar
okk but per moments the rpm down to 250...and not very good...the engien run like 1 or 2 cylinder missfire...
post #8 of 28 (permalink) Old 12-30-2013, 06:40 AM
Check the fuel pressure. You may need a fuel filter or fuel pump.
post #9 of 28 (permalink) Old 12-30-2013, 01:05 PM Thread Starter
volvering's Avatar
that's i think to but when i drive and need power the engine gave me what i wan't..it's around 1000-1500 rpm the problem arrived not on higher RPM.
post #10 of 28 (permalink) Old 12-30-2013, 08:11 PM
Idle air motor?
F150 - OBD CODE 1288 garymac221 F-150 2004 to 2008 Forum 3 10-20-2010 03:58 PM
Service Engine soon, DTC #p0171, p0174 gt40 Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 3 12-06-2009 02:15 PM
Code Help Ill Named F-150 2004 to 2008 Forum 5 05-04-2009 09:53 PM
Engine code blueghost F-150 2004 to 2008 Forum 3 05-22-2008 01:42 PM
Airbag,code 27 blueghost F-150 2004 to 2008 Forum 1 05-16-2008 11:16 PM
