Door ajar light stays on - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 06-22-2014, 06:37 PM Thread Starter
Ok this just happened today. The door ajar light stays on as do the cargo lights. I slammed each door closed to make sure they were closed and the lights still stays on.
I've sprayed about 3/4 of a big can of wd-40 into each latch and open/closed each door 8-10 times each time I sprayed. It seems to be the two rear doors that are the issue. After spraying the crap outta them and opon/close about 40 times each I finally got the light to go off, but the very next time I open/close that door the light comes back on and stays on. SO then its another round of spray&pray. Once I got the lights to go off again I left it alone, but I know the next time a door is open I'll be back where I started. I really dont want to have to keep disconnecting the battery every time I park it.
Any other suggestions would help. I thought about pulling the fuse but from I have researched that will also disable the PW and maybe the PL.
post #2 of 4 (permalink) Old 06-22-2014, 07:10 PM Thread Starter
Ok I think I may have found the issue. Possible driver error. Never having had PW/PL before I think I goofed up. When I press the unlock button on the key fob the lights in question come on. When I close the doors without locking them the lights stay on, but if I press the lock button on the key fob the lights go out. I hope this fixes it. Driver error I can live with, annoying electrical gremlin I can't
post #3 of 4 (permalink) Old 06-22-2014, 07:54 PM
Instead of wd40. Pick up some RUST CHECK. Red cap. Works better I find on latches and hinges. And smells better. !! lol
post #4 of 4 (permalink) Old 06-22-2014, 08:10 PM
I like Fords Too's Avatar
I've been told rustcheck has teflon in it - that may help
my 01 seems to have a time delay for the interior lights
getting in , unlocking the door with the fob , the dome light stays on until the key is turned in the ign or some time passes
getting out the light stays on for a bit then goes off after some time passes but if I press the lock button on the fob they turn off right then
I like Fords Too is offline
Door Dings? FlightSergeantRose F-150 2009 to 2014 Forum 15 08-02-2011 02:20 AM
NEED HELP: DOOR HINGES big-papa F-150 Pre-1997 Forum 3 06-01-2010 02:38 AM
Door Hinges JimyB Sticky Tech/How to Section 14 04-09-2010 12:12 AM
NEED HELP: Door Ajar Warning Question conductr Ranger Forum 5 11-02-2009 03:38 PM
Door Ajar Light Stays On William Young Ranger Forum 6 04-14-2008 01:48 AM
