4.6L won't fire after rebuild - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 08-10-2014, 08:10 PM Thread Starter
Clydesdale's Avatar
Question 4.6L won't fire after rebuild
Truck = 1998 F150 with 4.6L Windsor SOHC
I just completely rebuilt the engine including pistons, rings, timing chains (timing is good; compression @ 180 psi), 2 new coils, wires, plugs etc. and there's no fire at the plugs when I crank it. It turns over good but doesn't start. The fuel pump comes on and there's fuel up to the injectors. Before I disassembled the engine, it still ran good except for one piston. The 2 new coils, wires, plugs were replace before I rebuilt it. I was very thorough when re-installing the electrical etc... and triple checked it all after the engine not firing. Fuses are good. I know it's hard to trouble shoot without seeing the truck but I'm just looking for ideas? The battery has been disconnected for months as I started a long time ago. Computer maybe?
Clydesdale is offline
post #2 of 9 (permalink) Old 08-11-2014, 08:03 AM
Crank and/or cam position sensor?
post #3 of 9 (permalink) Old 08-11-2014, 12:34 PM
Did you time the engine correctly ?
post #4 of 9 (permalink) Old 08-12-2014, 12:01 AM Thread Starter
Clydesdale's Avatar
Fixed!!! It was the crank sensor that was unplugged; the only one I forgot to plug in.
Runs absolutely beautiful.
post #5 of 9 (permalink) Old 08-12-2014, 01:36 AM
Damn, he did it again!
post #6 of 9 (permalink) Old 08-12-2014, 05:42 AM
Nice, another win for the fordtough.ca talent. lol
post #7 of 9 (permalink) Old 08-12-2014, 07:59 AM
Oops! Sorry.
post #8 of 9 (permalink) Old 08-30-2014, 08:33 PM
At least it was just the CKP sensor connector. There's nothing worse than looking on the bench after the front cover is on and seeing the tone ring staring back at you. lol
Varsity Tyler is offline
post #9 of 9 (permalink) Old 09-16-2014, 10:00 AM
Big Daddy D.'s Avatar
I see that you managed to solve it . Next time your stumped, check with a member on here by the name of "JimmyK"
He's one of the top Ford Truck Tech's in the Country (when Ford dealers mechanic's got stuck, and they would phone the Ford hot line, he was one of the ones who would be there to answer the phone...)
Jim now works at the Oakville Ford Plant with the engineers there.
Press on regardless!
Big Daddy D. is offline
2004 transmission rebuild danr F-150 2004 to 2008 Forum 2 01-25-2013 10:21 PM
NEED HELP: Top end rebuild instructions smokeshow Gas Engines 9 05-18-2012 12:28 AM
Inline 6 rebuild Jensen Gas Engines 15 01-14-2009 07:08 PM
1981 Ford F150 5.0l rebuild Jensen Gas Engines 15 10-25-2008 01:23 AM
4.0L rebuild in London not.too.low92 Gas Engines 4 08-20-2008 05:07 PM
