2000 ford f150 XL 4x4 triton v8 nothing works - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 21 (permalink) Old 11-23-2014, 05:55 PM Thread Starter
Mechanic
Hi.. I parked my ford last night like I usually do and I woke up this morning for work I started the truck and notice that all the guage needles went to high, then I I tried to shift from park to drive and it wouldn't allow me to shift, then I tried my 4x4 that would not engage either, my wipers, radio, signals and interior lights don't work .how can all this just stop working from last night. any suggestions from all the experts out there.
thanks
tasmanian satellite is offline
post #2 of 21 (permalink) Old 11-23-2014, 06:35 PM
All that and the soft clutch too. If it weren't for bad luck.....
post #3 of 21 (permalink) Old 11-23-2014, 06:59 PM
I like Fords Too's Avatar
sounds like something at the core of power distribuation
there's a box full of relays and fuses under the hood of most newer stuff - your's would be the flat top box by the brake master cylinder
possiably a bad fuse or relay - maybe a short - could be salty water in the box somehow
just a guess / shot in the dark but I'd start by lookin there
I like Fords Too is offline
post #4 of 21 (permalink) Old 11-23-2014, 07:13 PM
2x but with one thing to check first. Check the grounds first. Give the ground bolts a small turn tighter. 1/8~1/4 turn should do it.
post #5 of 21 (permalink) Old 11-23-2014, 08:20 PM Thread Starter
Mechanic
yeah eh
post #6 of 21 (permalink) Old 11-23-2014, 08:23 PM Thread Starter
Mechanic
I will try suggestions please keep on giving your suggestions still.
thanks
post #7 of 21 (permalink) Old 11-24-2014, 10:18 PM
Body control module?
05 F150 Lariat Screw.
89 LX5.0 usual mods.
ronburgundy is offline
post #8 of 21 (permalink) Old 11-26-2014, 11:51 AM Thread Starter
Mechanic
Hi.. where would the body control module be located.thanks
post #9 of 21 (permalink) Old 11-26-2014, 08:39 PM
Everything is located behind the left side of the dash. GEM, CTM...
post #10 of 21 (permalink) Old 11-30-2014, 12:31 PM Thread Starter
Mechanic
sorry im really not mechanically inclined would that mean I would have to remove the dashboard? is there a diagram or photo that would show this module. thanks for being patient
2000 F150 Flare Side lookoutFors cdnarmyguy F-150 1997 to 2003 /04 Heritage Forum 18 10-01-2011 09:55 PM
2000 F150 problems cdnarmyguy F-150 1997 to 2003 /04 Heritage Forum 1 08-20-2011 11:33 AM
NEED HELP: 2000 Ford Ranger-Wheel Bearing... mustangracer5_0 Ranger Forum 2 11-11-2009 01:27 AM
biggest tire on 2000 F150 truckman79 F-150 1997 to 2003 /04 Heritage Forum 6 11-07-2008 01:40 AM
Ford Excursion owners manuals (2000 - 2005) excursionking Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 0 11-30-2007 11:50 PM
