97 F150 4.2L V6 intake gaskets GRRRRRR - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 02-21-2008, 10:31 PM Thread Starter
canadian redneck's Avatar
Send a message via MSN to canadian redneck
Unhappy 97 F150 4.2L V6 intake gaskets GRRRRRR
How many of you have had anything to do with these problem gaskets, and how bad are they to change if you did it yourself?
canadian redneck is offline
post #2 of 3 (permalink) Old 02-22-2008, 01:23 PM
Just got answer from my mechanic
Main thing to go on 4.2L would be blown intake gaskets, or timing cover gaskets
I think f150phule did some digging into it
post #3 of 3 (permalink) Old 02-23-2008, 12:13 AM
Yeah digging into my wallet for about $1500.
If you check that website posted earlier www.v6f150.net they have a whole section just for the 97-98 hydrolock issue.
Basically heres my version.
Check the drivers side valve cover for the engine build date on the sticker.
If the date is after 01/15/98 then you have the updated gaskets.
The main issue was Ford put gaskets in the timing cover that were too thin causing coolant from the overflow bottle to leak into the #1, #4 cylinders.
If you have noticed that your coolant level in the over flow bottle keeps going down and you have to top it off once a week and you see no visible leaks then your just begging for a hydrolocked motor. Change em ASAP.
The parts are cheap, when I had mine done I had them change the upper/lower intake gaskets and the timing cover gasket. Make sure you buy the FORD gaskets not the Felpro ones so you'll have to buy them from the dealer. A few other minor things had to be fixed as well on mine, new T-stat and headbolt. The cost for just the gaskets should be about $120 depending on where you go. What killed me was the repair is wayyy beyond my skill level so I got nailed on the labour, the book says to replace all 3 gaskets is a 12hr job.
If you can do this job yourself you will save tons of $$$. Hell if I could do it myself I'd have changed the head gaskets too.
If you have any more questions I'd be happy to answer em here or at a GTG.
Intake For 07 v6 stx STXPrincess Ranger Forum 6 03-16-2008 07:37 PM
98 f150 ext cab 4x4 cold air intake problem..help duece F-150 1997 to 2003 /04 Heritage Forum 6 03-03-2008 10:24 PM
Whistling intake littlebronc F-150 2004 to 2008 Forum 18 02-27-2008 05:08 PM
