shudder from back end dureing slow left turns - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 13 (permalink) Old 04-06-2015, 12:15 PM Thread Starter
I like Fords Too's Avatar
title pretty much sums up the issue
low speed left turns I get a shudder like something is grabing or binding
turning left from a stop or almost stop - turning left as I go through a drivethrough driveway etc
almost feels like I'm pushing the right front tire sideways across the ground without it turning - it's that choppie feeling - but I'm absolutely sure it's comeing from the back axle - maybe the left side (where I had the axle seal fail last september???)
truck is an 01 with rear disc brakes and limited slip diff -I'm thinking I'm feeling the caliper grab or bind on the rotor as the axle flops about as the truck is changeing direction
- and maybe the axle is a little slow keepin up
I'm hopeing it's not the diff failing to let the wheels turn different speeds or grinding , binding and locking / unlocking
-what do these diffs do as ther start to fail? just to be sure - I haven't had to fix that .. yet on this truck lol
- has 316 000 km's on it just now
ever since I first drove this truck back in the summer of 02 I noted a strange disconnect / connect feeling come from the back axle when makeing slow speed left turns
it's this sensation that's become much much stronger I think - AND that's what makes me worry it's the diff
any input is welcome - usefull input more so
I like Fords Too is offline
post #2 of 13 (permalink) Old 04-06-2015, 10:53 PM
TRNRBILT's Avatar
It could need more of the friction modifier added into the rear diff. My grandfathers gm did the same thing. Poured a container of it in and fixed the issue. If its not in the gear oil it doesn't let the L/S plates slip they just bind.(from what I was told)
TRNRBILT is offline
post #3 of 13 (permalink) Old 04-06-2015, 11:30 PM
Sounds about right. Won't hurt to try it.
post #4 of 13 (permalink) Old 04-07-2015, 06:52 AM
Big Daddy D.'s Avatar
Yup, a can of friction modifier is cheaper then a $700.00 repair bill re: the clutch packs.
Press on regardless!
Big Daddy D. is offline
post #5 of 13 (permalink) Old 04-07-2015, 07:35 AM
Change the rear diff oil to a synth oil with modifier in it.
post #6 of 13 (permalink) Old 04-07-2015, 11:06 AM
5pointslow's Avatar
sounds like clutch packs. just had it happen in my '10. change the rear diff fluid, add a container of the friction modifier. for some reason, I had to add a second container. first one dint seem to fix the problem. been good since I added the second. and at ~$5 from the dealer its the cheapest/easiest place to start.
some people say to drive slowly in circles after you add it to help it work its way into the clutch packs. cant hurt? may get dizzy...
5pointslow is offline
post #7 of 13 (permalink) Old 04-07-2015, 01:27 PM Thread Starter
thanks guys
I've been kinda wondering if , IF I even have any of the friction modifyer in the diff fluid
since I had the axle seal leak like mad back in september , and had the diff cover replaced a couple of years ago - it's very possiable it has none or not enough
good first try - fix in a bottle - only slightly less perfect than things that simply fix themselves
speaking of which it didn't do any shuddering last night or yesterday - same drive through too
(prob means it's seconds from total destruction lol)
post #8 of 13 (permalink) Old 04-07-2015, 01:46 PM
Canadian Bacon's Avatar
Figure 8's not circles. Gotta work it in on both sides.
Start with 2oz (half a bottle) of friction modifier. Work it in. If it continues add the other half. 4oz should treat up to 3L.
Except for Motorcraft, most companies already put some modifier in the lube.
Emily - 2010 Ford F-150 FX4
Amsoil Independent Dealer
Amsoil Home Page
Canadian Bacon is offline
post #9 of 13 (permalink) Old 04-07-2015, 01:52 PM Thread Starter
thanks - I'll go over and see about getting some this aft
post #10 of 13 (permalink) Old 04-08-2015, 10:48 AM
5pointslow's Avatar
same difference but I did about 10 circles clockwise and then 10 circles counter clockwise.
country boy, winter, it was easier to find a space to do that than enough room to do figure eights. i'm sure either will work if you have the space.
05 5.4 Edge CS slow stage 3 OFD#17 Programmers and Tunes 8 10-20-2012 03:15 PM
NEED HELP: slow coolant leak oilman Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 3 10-30-2011 11:37 PM
Fun day Mudding Turns into this.. Coruptyed Photo and Video Gallery - Members Rides 51 01-22-2011 12:27 PM
Slow around here B Rent F-150 Pre-1997 Forum 4 06-08-2010 03:48 PM
NEED HELP: truck starts but turns off hawker250 Gas Engines 10 05-24-2010 01:26 AM
