98 f150 ext cab 4x4 cold air intake problem..help - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 03-02-2008, 11:50 PM Thread Starter
i installed a cold air intake on my 4.6 lt and approx two weeks later i have this sound that sounds like a air pump doing something funny (very loud) and makes the rpm's go up and down ..anyone have this problem ,know whats going on or know a fix....hopefully i explained this right..thanks to fx4 matt for the invite tothis site..sorry for not saying hello first guys..great to be here.
duece is offline
post #2 of 7 (permalink) Old 03-02-2008, 11:57 PM
PM SKRWZ
He is expert on them
Make sure you tell him what model do you have
post #3 of 7 (permalink) Old 03-03-2008, 12:36 AM
First:
welcome to the site
Second:
What CAI do you have?
How much milige is on the truck?
You may have a dirty IAC Valve
Are all the connections tight?
You may have a vacum leak
post #4 of 7 (permalink) Old 03-03-2008, 12:56 AM Thread Starter
its an in expensive brand i bought off of e-bay..i think i paid about 80.00 came with polished pipe fittings clamps hoses air filter and heat sheild,the truck has approx 160.000kms on it runs good i just put dual exhaust on it to..everything seems to be tight and assembled well..i dont think i have any vacuum leaks ..whats a iac valve?? sorry
duece is offline
post #5 of 7 (permalink) Old 03-03-2008, 06:48 PM
I would check all vacuum lines, Pcv, hoses, elbows etc for leaks/cracks etc check the rubber elbow on he pcv line that plugs in the back of the intake that one is famous for cracking, also check for a clogged PCV valve,
you can tap on the IAC valve (idle air control) with the engine running it may be stuck and in need of replacement or cleaning, on a 4.6 I believe it is beside the throttle body
IAC valve pic
post #6 of 7 (permalink) Old 03-03-2008, 06:49 PM
Originally Posted by 08limited View Post
PM SKRWZ
Expert...LOL
post #7 of 7 (permalink) Old 03-03-2008, 10:24 PM Thread Starter
thanks for all the great info i will try those tips and let you know,thanks again
duece is offline
NEED HELP: Cold Air intakes black on black fx2 F-150 2004 to 2008 Forum 16 07-25-2009 07:20 PM
Cold air intake... off road kits_hacker F-150 2004 to 2008 Forum 27 10-15-2008 12:30 PM
2007 4.6 cold air intake sid60 F-150 2004 to 2008 Forum 1 09-19-2008 02:15 PM
Sound System for ext cab ranger 92_ranger Ranger Forum 4 03-19-2008 11:38 PM
Cold Air Intake? Coruptyed Intake, Exhaust 22 03-01-2008 04:26 PM
