a little upgrade - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 09-20-2015, 07:07 AM Thread Starter
I like Fords Too's Avatar
a little upgrade
01 f150 , 5.4
truck's been ticking again for a while , most of the summer so it was time (long past due) to check the spark plugs
first I checked each by putting a mechanic's steathiscope to the top of each coil
the front most passenger side coil , I could actually hear the ticking coming from the coil
turns out that one was lose enough I could spin the extension and plug socket easilly in either direction - with quite a bit of turning before it snugged down again
- the other 3 plugs behind all also needed torqued tight again but at least it didn';t take a few turns of the plug first
so lesson learned - if I can hear it actually ticking it's probably ready to blow outta the head
some on the driver's side also needed tightening but not the one with the thread repair I had done 3 years ago
all the plugs were replaced 3 years ago when I had the one thread fixed - about 23 ooo km's ago
so , anyways ... while I had the truck torn into I installed a little upgrade I've had waiting in a box for a couple of years .. yeah I finally got a round to it
1 set MSD coils and one set granatelli coil to plug leads and boots
the coil leads use a solid length of steel cable instead of the flashlight battery springs usually found in the coil boots lol
and what a nice little reward for the effort
all my truck's ticking is gone
yippie
and , Idono if it's the coils or the coil leads but the betterment in driveabality and throttle responce cannot be denied
all I can say is before the coils and leads , even with the plugs tight and new back when the thread repair was done , the throttle responce was always slushie by comparison to how crisp the responce feels now
added benifit , now I have a full set of new coils ... all at the same time , not randomly replaced ones like I had
+ I have a new in the package spare msd coil in the glovebox in case I need it
before you bring up the subject of just replaceing the coils with ford ones I'm going to point out , that my truck has had about 14 of fords dammed coils installed in it - all but the last pair cost my father about 400 bucks and some change because the bill always got padded out like they tryed to do with me by sujesting the fuel injection service was due
arugh ... so anyways , ford's made more than a fair share from a problem they managed to design into their product then their dealers managed to milk that for even more
I am not going to continue to reward ford for building crap so no more ford coils go into the damed truck from now on
next up , I have another ignition upgrade
back when I bought my coil set I also hunted down a msd stacker 8 ignition box
basically your usual cd ignition and multy spark msd deal , but intended for use with coil pack or coil on plug motors
no rev limiter , not like you'ld need that with it in the ecu anyways
- aaand it's a perfect fit mounted on top of the lid for the under hood fuse / relay box & even still allows the lid to be raised & closed like normal
- it's been mounted on the box now for about a month and I see no rub mark on the under hood pad so I guess that clears too
got the box second hand , thank god (ebay) 'cause new they were 7-8 hun
coil set was expensive enough and so were the coil leads
(coil leads wre about $150 /60 - tink I gottem from jegs)
I think they make the coil leads for 4 valve motors too but maybe not the 3 valvers
I still have the box for the coil leads so I'll add the part number later
pics as always are in my album
http://www.fordtough.ca/forums/album.php?albumid=563
blue boots seem more silicon-ie than the black ones that came with the msd coils
blue boots came with the granatelli coil leads
steel cable connection , no radio noise - if anyone thought to wonder
I like Fords Too is offline
post #2 of 11 (permalink) Old 09-20-2015, 08:19 AM
Looking good, congrats on the new mods ! No substitute for regular maintenance and a little TLC.
post #3 of 11 (permalink) Old 09-28-2015, 12:13 PM Thread Starter
coil leads :
http://www.jegs.com/p/Granatelli/Gra...64428/10002/-1
ok , granted I put a set of msd coils on too when I installed these
BUT , I would recomend , after driving my truck for one week and two weekends since I did the work above buying these leads without reservation
I doubt the msd coils are entirely responceable for the better drive quality I'm experanceing now
in fact the difference , feels like it was always trying to spark through a set of flashlight battery springs
the truck feels like the coils are connected by steel winch cable sections
good sharp throttle responce , I can actually crack the throttle with much more authority than ever before
this is simply the best thing I've ever done for my truck save for swaping off the warped brake rotors
post #4 of 11 (permalink) Old 09-28-2015, 12:22 PM Thread Starter
one thing to add regarding installation
I found I had a little trouble getting the lower terminals on some of the plugs as I pushed em down into the spark plug wells
the solution was dirt simple
install the lead onto the terminal on the coil , then remove and flip the lead over and install the opposite end onto the coil
it seems the terminals install onto the plugs much easier if they've been pre streached on the coil terminals first
oh , and these leads actually have terminal ends just like any regular plug wire found on any other older motor
considering how high voltage run through a wire can cause the wire to bounce around I can figure the spring style connectors might just be bounceing and buzzing around everytime the coils fire
which may well be why I'm feeling the difference I am now
post #5 of 11 (permalink) Old 09-30-2015, 06:39 PM Thread Starter
K
I've read many places the ford stuff is as good as any or better
yeah , doncha ####### believe that ...
after this little swap in all I can say is I'm so freeking glad I did this - the truck drives better now with 325 000 KM's on it with the msd coils and granatelli coil leads than it ever did when brand new
for all the pump and praise the ford stuff keeps getting , Idono , brainwashing ??
must be 'cause the ford chit sucks bags of dog poo compared top these parts
no more feeling like the gas peddel is connected to a bungie cord - I get instant throttle snap NOW , every time I want it
I even got a little tire slip on dry pavement this morning - something my truck has never been able to do before unless there was a good bit of dust or grit on the road
- and yesterday in the rain ...
lol , yeah ... I'm going to have to be just a little more gentle starting away from a stop in the wet now as the tires break lose with zero effort now
post #6 of 11 (permalink) Old 10-13-2015, 06:36 PM Thread Starter
wow
270 views and no comment
guess peps get lost when the stuff they've been told over and over turns out not to be true
post #7 of 11 (permalink) Old 10-13-2015, 07:41 PM
Canadian Bacon's Avatar
When the MSD ones crap out in a year or so and you go back to the OEs there will be lots of comments lol.
This winter/spring I am going to do the plugs and coils on the Lightning with OEM parts. There are trucks pushing 700 HP and still using OEM coils.
Emily - 2010 Ford F-150 FX4
Amsoil Independent Dealer
Amsoil Home Page
Canadian Bacon is offline
post #8 of 11 (permalink) Old 10-13-2015, 08:26 PM
Glad the aftermarket's giving you the results you need, bad run of luck that the Ford parts didn't do as well, doesn't mean they're any better or any worse, its just how your personal experience shook out.
Like Ryan suggested, probably just as many stories of guys returning to OEM as there are guys moving away from them.
post #9 of 11 (permalink) Old 10-13-2015, 09:08 PM Thread Starter
yeah
I don't think the coils are the improvement - more like the coil leads themselves
but regardless , no more ford coils as I said before
post #10 of 11 (permalink) Old 10-13-2015, 09:11 PM Thread Starter
you might be doing yourself a favor trying those coil leads
I can't say strongly enough how much like it isn't connected by some gay little springs it feels now
I chit you not mang
Anybody Done the Navigation Upgrade?? 97350 F-150 2009 to 2014 Forum 9 09-03-2014 01:42 AM
What would you upgrade first on your truck ameaney F-150 1997 to 2003 /04 Heritage Forum 12 10-23-2011 09:53 AM
NEED HELP: 04 upgrade jbone F-150 2004 to 2008 Forum 5 01-04-2011 11:22 AM
Stereo Upgrade Cowboy Audio and Electronics 1 09-15-2010 12:12 PM
brake upgrade broncojohnny Suspension 8 04-17-2010 06:15 AM
