Cluster - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 20 (permalink) Old 03-22-2008, 10:28 PM Thread Starter
Question Cluster
Hi,
I'dlike to know if this have happened to someone. I have a cluster problemon my F150 XLT 99. The digital odometer sometimes light up, sometimes not. It occurs while running. It can be lighten up, then suddenly close. Do I have to change the entire cluster unit ??? Thanks.
blueghost is offline
post #2 of 20 (permalink) Old 03-22-2008, 10:50 PM
common problem. Happened to me too.
Not a big deal as it still counts the km, you just can't see it sometimes... but yes you would have to replace the whole cluster.
Frumpy is offline
post #3 of 20 (permalink) Old 03-22-2008, 10:53 PM
I think I saw on another forum ppl that had this issue,not sure if there is a fix for it other than replacing the cluster.
post #4 of 20 (permalink) Old 03-23-2008, 12:36 AM
I have seen the repair for this somewhere and I cant remember where exactly at the moment but I belive the issue is a broken solder joint on the cluster if i find more info on this I will post it up for you
post #5 of 20 (permalink) Old 03-23-2008, 12:41 AM
Coruptyed's Avatar
ya this problem is very common, and skrwz is right there is a joint that is causeing the problem, thats how most have fixed theres.
The F150 UFO
Coruptyed is offline
post #6 of 20 (permalink) Old 03-23-2008, 08:26 AM
alpine's Avatar
Do not replace the cluster, there is an easy repair if you can get the cluster out and you have a soldering iron.
This is the site with the instructions(with pictures):
http://www.f150online.com/forums/sho...light=odometer
alpine is offline
post #7 of 20 (permalink) Old 03-23-2008, 09:12 AM Thread Starter
Thanks all for answering so fast.
I planned to remove the cluster today to do a check... Will get the soldering iron out too :-)
post #8 of 20 (permalink) Old 03-23-2008, 10:26 AM
well I have this probleme too, rarely happends I just tap the cluster and it lights back up rite away.....just started and my dash was taken apart not that long ago must have roughed up the connection
post #9 of 20 (permalink) Old 03-23-2008, 01:31 PM Thread Starter
Cool
Cluster is removed and all goes well. Didn't take a lot of time.
However, soldering iron is out and magnifying glass is not very good
Will wait tomorrow and get another one at Canadian tire...
Hope re-connnecting it will be that easy lolll.
Thanks all for your help, it was really appreciated
post #10 of 20 (permalink) Old 03-27-2008, 09:12 PM
sledmanjones's Avatar
I did this on my 99 and it was very easy.Just get the soldering iron hot and heat each pad on the odometer until it liquefies,if there is very little solder and you feel you need to add some,get solder for electronics,not for pipes, but it works great,and doesn't cost much more than your time to do it.
sledmanjones is offline
Gauge cluster swap on a 97-98 F150 with analog odometers f150phule Sticky Tech/How to Section 2 10-20-2008 01:09 AM
Installed new gauge cluster w/Tach f150phule Interior 9 10-19-2008 06:51 PM
Instrument Cluster / Gauges Upgrade fordtough.ca Interior 4 03-29-2008 06:06 PM
Roush Performance Series Instrument Cluster fordtough.ca Interior 19 02-20-2008 09:47 PM
