1999 XL 4.2 litre battery light on - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 1 (permalink) Old 03-24-2016, 06:16 PM Thread Starter
Hi All, I bought my 1999 4.2 litre last fall and parked it in my garage over winter. Previous inspection showed the battery hold down bolt was seized. The weather warmed up and I tackled the bolt. Had to disconnect the battery to drill it out. To prevent loss of radio presets, etc., I used an obd2 memory saver from Can. Tire, connected to a 12 volt power pack. Did not lose any memory, but after I re-connected the battery, my battery light stays on. Light was not on last fall when I parked the truck, and I did not start the truck all winter. I haven't yet checked the fuse #11 (alternator field) but will shortly. Is it possible the memory saver power in conjunction with the 12 volts from the battery before I disconnected it could have caused damage? The battery and alternator both look quite new; the alternator is a Bosch (so obviously not the original) and the battery is Interstate. Any thoughts? Thanks.
donrogal is offline
Battery Light Flashing oilman Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 3 02-05-2015 07:36 AM
1999 f150 firing just on 4 cylinders.. volvering F-150 1997 to 2003 /04 Heritage Forum 13 11-07-2013 06:14 PM
NEED HELP: Battery light seanm Ranger Forum 9 01-01-2011 04:09 PM
1999 F150 new battery not holding charge relaychatter F-150 1997 to 2003 /04 Heritage Forum 3 12-23-2009 06:15 AM
1999 ranger sas lonerangerxlt Ranger Forum 5 12-15-2008 06:39 AM
