Aftermarket Tach install - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 14 (permalink) Old 03-31-2008, 11:12 PM Thread Starter
Hey all, I have a '98 F150 4x4 4.6L w/o a factory tach in the cluster, just wondering which wire I will need to tap into to get a signal, I picked up a tach that had the option of just using a spark plug wire but the signal is too erratic and I would like to just hook it up directly to the source, any help would be appreciated!
notmuchmud is offline
post #2 of 14 (permalink) Old 03-31-2008, 11:18 PM
post #3 of 14 (permalink) Old 03-31-2008, 11:48 PM Thread Starter
it has the standard 4 wires, (black,white,green,red) and a brown wire that has a thing that replaces the green wire in the install, its an equus i bought from crappy tire...haha
post #4 of 14 (permalink) Old 04-01-2008, 03:55 PM
Most aftermarket tachs have a switch, on the back or inside to select the # of cylinders
Also see below:
post #5 of 14 (permalink) Old 04-01-2008, 04:18 PM Thread Starter
Yah, it has a switch on the back but you only use that if you use the green wire cuz the spark plug wire pick-up elimates the use for the selector switch, but i will call around and see if i can find one with a tach in it already, i never thought of it, it would sure make things easier, i really don't like cutting into wires so that would eliminate that!
post #6 of 14 (permalink) Old 04-01-2008, 08:49 PM
1white08fx2's Avatar
With most aftermarket tachs,you will need the tach adapter to work with the Ford Ignition,had to on my '03 Mustang GT,and had to on my '85 Mustang GT.If this was for the '98 mustang,i would able to help you LOL,but i'm not familiar with the wiring harness of the modular Ford F series pick ups yet.
stripped,slammed,& cammed!
aka 1LOW03GT
1white08fx2 is offline
post #7 of 14 (permalink) Old 04-01-2008, 10:55 PM Thread Starter
Ahh ok....that makes more sense, I must have read through the instructions a ton of times for the install but nothing i did worked, the adapter would make sense tho, i will call around for wrecking yards tomorrow, i found a cluster out of i think it was around a '99 lighting but i wasn't sure if the 4.6 and the 5.4 gauge clusters were the same, hey grafix, that does look a ton better with the tach, it looks like the same one out of the superduty, except it doesn't say diesel fuel only...haha
post #8 of 14 (permalink) Old 04-02-2008, 12:26 AM
Would installing a cluster w/tach that has the digital odometer work in the 97-98s that have the analog odometer?
post #9 of 14 (permalink) Old 04-02-2008, 05:17 PM
Crap..thought I might have found a good deal...
http://cgi.ebay.ca/ws/eBayISAPI.dll?...MEWA:IT&ih=006
Marco --- how hard was it to find an analog cluster w/tach?? Price range??
post #10 of 14 (permalink) Old 04-04-2008, 11:39 PM Thread Starter
i managed to find an analog cluster for $100, i didn't have a hard time findin it, just called a few wreckin yards and they had a few to choose from, i was able to find the tach signal wire under the hood so i just used that one instead, i had already drilled the holes and mounted the tach so i figured it was easier tappin into a wire than it would be to yank out the cluster, it was the pink w/ white stripe which i found in the haynes manual
Installed new gauge cluster w/Tach f150phule Interior 9 10-19-2008 06:51 PM
aftermarket LayinHp Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 1 03-08-2008 04:35 PM
Aftermarket Wheels Advice white4by4 Wheels and Tires 8 01-18-2008 11:05 PM
