03 F150 XTR xtend cab-wheel bearings - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 06-07-2008, 07:56 PM Thread Starter
Would anyone possibly know the recomended torque setting for the wheel bearings on my truck. On the 3rd left front . Thanks.
gman is offline
post #2 of 6 (permalink) Old 06-07-2008, 08:04 PM
can't find my chilton right now. sorry. maybe another member can help. also welcome to the site!!! a chilton/haynes manual is like gold if you do any work on your truck. i recomend picking one up.:icon_smile:
post #3 of 6 (permalink) Old 06-07-2008, 08:10 PM
Hope this helps
if it is a 4WD this is the info
  • Bolt the unit bearing hub in to the new knuckle using red Loctite and torque to 80 ft/lb
  • torque the axle nut to 190 ft/lb
post #4 of 6 (permalink) Old 06-09-2008, 10:16 PM Thread Starter
Thanks very much SKRWZ info is much appreciated. THis one is only torqued to 100. maybe thats why they dont last.
gman is offline
post #5 of 6 (permalink) Old 06-09-2008, 10:38 PM
Cooker's Avatar
Even something as simple as overtightening Lug Nuts can greatly reduce wheel bearing life.
Cooker is offline
post #6 of 6 (permalink) Old 06-29-2008, 07:46 PM
jmc
jmc's Avatar
I don't understand how. Please elaborate.
Regards
Jean Marc Chartier
Regards,
Jean Marc Chartier
Warn XD900i E-fans, M5OD w/ Hurst short throw, Procharger @15psi, Troyer tuned.
Swap notes 4.6 to 5.4; http://www.f150online.com/forums/art...ml#post3570245
jmc is offline
Wheel balancing... HD Chrome Wheels and Tires 7 11-18-2008 06:48 AM
Sound System for ext cab ranger 92_ranger Ranger Forum 4 03-19-2008 11:38 PM
98 f150 ext cab 4x4 cold air intake problem..help duece F-150 1997 to 2003 /04 Heritage Forum 6 03-03-2008 10:24 PM
XTR, eh? spenny New Members Introductions 14 03-03-2008 05:01 PM
OUTSIDE of the obvious; Pros & Cons on s/crew to s/cab 4X4 EH F-150 2004 to 2008 Forum 11 01-20-2008 03:22 PM
