Next Project, U joint replacement - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 14 (permalink) Old 08-26-2008, 12:42 AM Thread Starter
Next weekend I will be doing my last project on my 2002 XTR so far,replacing both drive shaft U joints
If you guys like I can make pictures and post'm here.
Anybody has bad experiences doing this repair?
I would appreciate the heads up
jos1959 is offline
post #2 of 14 (permalink) Old 08-26-2008, 12:22 PM
I did 2 in the rear DS of my 350 earlier this summer and I am sure glad we had a tortch to heat the old ones up or I never would have gotten them out on my own. Even then it was a pain
post #3 of 14 (permalink) Old 08-27-2008, 01:30 AM Thread Starter
Thanks for the heads up, I expect some problems with it so I have a guy with a bench press on stand by
jos1959 is offline
post #4 of 14 (permalink) Old 08-27-2008, 12:52 PM
Not a hard job really, Jack the rear up so the tail of the trans is higher than the front to prevent fluid loss, now you'll need a 12mm 12 point socket to undo the bolt's heat them up fist to melt the locktite, before you remove the drive shaft mark the edge of the flange where it bolts to the pinion flange so you put it back the same way to prevent vibration issues, and the use of a impact is always helpful as well, then after it's out remove the clips and press the U joints out you can use a bench vise I used a ball joint press either should work, when you reinstall it put some red locktite in the bolts before you retighten them
post #5 of 14 (permalink) Old 08-27-2008, 01:54 PM
I did mine on a bench vise but they still needed lots o heat.
post #6 of 14 (permalink) Old 08-27-2008, 02:27 PM
You should never have to heat it up.. only gm trucks need to be heated for the first u-joint removal and thats all (becasue they use injected plactic instead of clips)
Vice or something to hold driveshft, hammer, plyers... pluse 15 minutes of youre time
snap-on is offline
post #7 of 14 (permalink) Old 08-27-2008, 03:49 PM
Mine needed heat. I tried in the vise with sockets to push it out with a 4' steel bar on the vise handle. Heated them up and they popped out in the vise. And yes I did remove the clips before I tried.
post #8 of 14 (permalink) Old 08-27-2008, 04:08 PM Thread Starter
Maybe next time try to WD 40 for a couple of days, I heard about that problem so I am soaking it now for the rest of the week.
Thanks SKRWZ for the note to jack up high enough to prevent transmission fluid loss.. never thought about that.
jos1959 is offline
post #9 of 14 (permalink) Old 08-27-2008, 04:26 PM
I'll definetly keep that in mind.
post #10 of 14 (permalink) Old 08-28-2008, 05:37 AM
Heat and BFH... No other way to do them. I know guys like the u-joint kits but I've found that unless they're fairly fresh then they're fairly useless.
Now, be thankful you're not stuck with my last u-joint job. 2 blown outter D35 u-joints on my current Ranger. Front end's NEVER been touched in 15 years, up country truck. First time I use the 4wd I find that they're bone dry and they proceed to gut themselves on the trail. Oops. Now they're banging and squeaking, one side blew 2 caps out from the stress. I finally get around to doing them, 9 hours to do two, they're completely seized and "rust welded" in place. I stripped the largest bench vise I could find at Princess Auto (big bastard too), found that copious amounts of heat and pounding was the only way to free them up. Tons of heat and a shot of WD-40 helps, as well as with the ones that blew the caps I stuck the welder in there and laid a bead on the inside of the caps, and the heat sucked them in and away from the yoke. Another trick was once you get one cap out use it to pound out the other caps. I think it would have been less painful cutting my own fingers off with a butter knife than that job. Half the fun of it all was just getting the spindles off the suspension beams in the first place!!!!
Being a 2002 they shouldn't be too bad though. Hell, mine just finally got all new u-joints at 265k and 15 years. Maybe the new ones aren't lasting as long? Just the front outters were bad, the rest were acceptable. The reason they spit the needle bearings out in the first place was because the previous owner never used 4wd, spit out the axles seals too (another fun job!). LR
So, whats your next project? fordtough.ca Projects and Build-Ups 69 03-18-2011 06:23 AM
new project martyF150XTR F-150 Pre-1997 Forum 10 08-16-2008 08:15 PM
wtf...05 u-joint snap-on Driveline and Transmission 2 05-15-2008 01:34 PM
Maintenance Manual - Mirror Replacement coggerwayne F-150 2004 to 2008 Forum 2 04-26-2008 02:52 PM
headlight bulb replacement FRagE Lighting 7 04-03-2008 10:30 PM
