BAD VIIIIIIIIIBRATION!!!!!!! - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 17 (permalink) Old 09-01-2008, 06:19 PM Thread Starter
my 03 supercrew 4x4 has an intermitant vibration at any speed. When it happens it is so severe you think you eyes are gonna vibrate out of your head.Suspect rear end as it is definately in the back. U-joints are fine and it happens even when I tried my winter tires . Rear end is LS 3:73, any ideas? or any one had a similar problem?
03supercrew is offline
post #2 of 17 (permalink) Old 09-01-2008, 06:55 PM Thread Starter
bad vibration
my 03 supercrew has an intermitent vibration that will shake you right out of the truck. It happens at any speed, and I have to stop. Once I start again it seems fine. It is in the rear and suspect the rear diff is the problem. It is LS with 3:73's . Has any one had any similar issues ? The truck has 80k on it.
post #3 of 17 (permalink) Old 09-01-2008, 06:58 PM
post #4 of 17 (permalink) Old 09-01-2008, 07:02 PM
i wonder if the LS is buggering up. might want to drain the oil and replace with new and a friction modifier for the LS.
post #5 of 17 (permalink) Old 09-01-2008, 07:14 PM Thread Starter
I had the drive shaft out & checked , u-joints all ok and I did change the 75w/140 to the ford friction lube, but sill having the same problem. There were small filings on the magnet on the fill plug.
post #6 of 17 (permalink) Old 09-01-2008, 09:11 PM
Top of my head... bent axle or rim???
and a small amount of filings on the magnet on the fill plug is normal wear
post #7 of 17 (permalink) Old 09-01-2008, 11:16 PM
check you tires.. you might have a twisted belt in it which happens a lot with snow tires, change back you regular tires to eliminate at least 1 variable
jos1959 is offline
post #8 of 17 (permalink) Old 09-03-2008, 08:01 PM
did you pull the u-joints right off and check them or just check for play? they sometimes will seize up and cause a vibration maybe pull the driveshaft out and try moving them and see if they are seized
yah sorry i guess i shoulda read more then just the first 2 posts, i didnt see you had already done that
kits_hacker is offline
post #9 of 17 (permalink) Old 09-04-2008, 08:43 PM
stuck ebrake?
tt64vert is offline
post #10 of 17 (permalink) Old 09-08-2008, 02:50 AM
grab ur back wheel at ten and two and give it a shake and test for play...without looking right at it its rly hard to say...
CHOCO is offline
Nice truck....Bad pic Bush_aholic Photo and Video Gallery - Members Rides 18 04-18-2008 09:33 AM
one bad bronco v8ranger Photo and Video Gallery - Members Rides 6 02-08-2008 11:49 AM
