Pink Rad anti freeze - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 19 (permalink) Old 10-23-2008, 11:52 PM Thread Starter
Bruicer's Avatar
Anyone help me out my son's 97 F150 the rad fluid is a pink and oily any idea what it might be ???
Bruicer is offline
post #2 of 19 (permalink) Old 10-24-2008, 12:04 AM
Probably coolant with out any water?
Or does it have oil residue to it
post #3 of 19 (permalink) Old 10-24-2008, 12:12 AM Thread Starter
Bruicer's Avatar
Hey White Peal yes it has a oil residue to It like slim
Bruicer is offline
post #4 of 19 (permalink) Old 10-24-2008, 12:20 AM
Old coolant will gel up and look very similar to grease/oil
Do you have anything in overflow container?
post #5 of 19 (permalink) Old 10-24-2008, 12:24 AM
I would go for a coolent flush ASAP, especially before it start to get cold.
post #6 of 19 (permalink) Old 10-24-2008, 12:24 AM
BTW
I have never seen oil in the water
Its always the other way around, as water is under more pressure
post #7 of 19 (permalink) Old 10-24-2008, 12:31 AM Thread Starter
Bruicer's Avatar
Done the flush checked the trans fluid it was way down just wondering if the tank that the keeps the trans fluid cool isnt cracked and its getting in the rad now im not sure what it is
Bruicer is offline
post #8 of 19 (permalink) Old 10-24-2008, 12:35 AM
Pressurize your rad and let it sit for a bit, and see if you lost any coolant
Also change your oil and coolant and see if the fluid in the rad looks the same as tranny fluid
post #9 of 19 (permalink) Old 10-24-2008, 12:44 AM
possibly tranny cooler line.could be leaking into the rad?
post #10 of 19 (permalink) Old 10-24-2008, 12:53 AM
murray99's Avatar
If you pull the trany dipstick and its all cloudy and starting to turn pink more than red and clear you have a leak. I have never seen a factory internal cooler leaking. If it is than I would think that trany pan should come ASAP as any moisture in the trany is a bad idea....factory antifreeze is now red and as Matt says it will gel up and look like slime. Flush the coolant
and refill with Ford antifreeze and you should be good to go...
murray99 is offline
how do you remove the stock rad fan drive shaft? lightning25 F-150 2004 to 2008 Forum 2 03-16-2008 09:47 PM
