Ready Lift torsion key lift - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 12-29-2008, 11:38 PM Thread Starter
Ford00XLT's Avatar
Exclamation Ready Lift torsion key lift
I am looking for your opinion on this system lift.
Ford00XLT is offline
post #2 of 7 (permalink) Old 12-30-2008, 01:35 AM
I wouldn't install aftermarket torsion "KEYS" although there a cheap way to get some lift you will be putting too much preload on the bars and getting too much angle on the CV's with them and getting a really crappy ride if you want to just level it out you can just adjust your factory torsion bars just watch your angles (don't go too extreme) and make sure to get an alignment afterwards
Remember too much angle and you will tear the CV boots and cause added wear on the CV's and ball joint's
IMO you pay for what you get
post #3 of 7 (permalink) Old 01-13-2010, 03:57 PM Thread Starter
Ford00XLT's Avatar
Found this on F150online:
"just crank up the torsion bars to the top the crank them back down 2 complete turns this will give you more than level and you can clear up to 33" tires! why pay the money for something you can do for free? plus all the extra money that you have to spend when your CV joins and ball joints go in the crapper because the bad angles! just my .02"
Would it be to extreme?
post #4 of 7 (permalink) Old 01-14-2010, 04:49 AM
I had my torsion bars cranked for years before I lifted my truck I wouldn't recommend cranking them past 27 degrees or you will wear out your CV's and possibly tear the boots as well as well as wear your ball joints faster, and most likely your ride will be too harsh.
BTW, I am still running my factory CV's
post #5 of 7 (permalink) Old 01-14-2010, 11:00 AM Thread Starter
Ford00XLT's Avatar
Any special tool to check the angle? Going to fit 33" under.
post #6 of 7 (permalink) Old 01-16-2010, 11:53 AM
01f150's Avatar
You do know you can fit 33's on it stock right? I have 285/70/17 (33x10.5) on the stock wheels with no rubbing.
01f150 is offline
post #7 of 7 (permalink) Old 01-16-2010, 11:33 PM
True and you can fit 35's on with a torsion bar crank and a body lift but it depends on what look you like
NEED HELP: Torsion Bar Lift 03MazdaB3000 Suspension 21 12-15-2008 07:22 PM
2"lift gewiens Raptor, Harley-Davidson, Limited, King Ranch, 60th Anniversary, Platinum 5 12-14-2008 03:48 AM
NEED HELP: "Ready Lift" Levelling Kit Bong80 Truck/SUV Talk 5 10-31-2008 06:57 PM
how much lift do i need? arboc Wheels and Tires 12 10-16-2008 10:15 PM
Lift, what do you............... fordtough.ca Off Road 20 06-19-2008 09:17 PM
