Heater problem - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 15 (permalink) Old 01-07-2009, 01:59 PM Thread Starter
Heater problem
My Truck developed a problem with the heater today,it will not blow heat unless the switch is on the High Setting.Has anyone else had this problem?
the truck is a 03 F150 with A/C.
Any help would be great.
thanks
RedFlareside4X4 is offline
post #2 of 15 (permalink) Old 01-07-2009, 02:13 PM
Do you have the dial heater control knobs on it?.... if you do pull the one off that goes from hot to could and look at the back side of it they were prone to crack and break
BTW welcome to fordtough.ca
post #3 of 15 (permalink) Old 01-07-2009, 02:36 PM Thread Starter
mine has 3 knobs ...one controls hot and cold air,one is for A/C and heater ,the other one has 4 Fan setting's from lo to Hi.i can feel the knob clicking on each setting but the heater only blows hot air on the Hi setting.but i will pull the knob off and check it out.
post #4 of 15 (permalink) Old 01-07-2009, 05:02 PM
I had the same problem in my 99 350 and it was the resistor, cheap fix.
post #5 of 15 (permalink) Old 01-07-2009, 05:46 PM
sorry I must have read this post wrong like Fordwheeler said it does sound like the resistor
post #6 of 15 (permalink) Old 01-07-2009, 09:49 PM
I had the same problem, I didn't have low and medium for a while then I lost high. It's in the engine bay.
Oreo is offline
post #7 of 15 (permalink) Old 01-08-2009, 08:21 AM Thread Starter
what was wrong in the engine Bay?
post #8 of 15 (permalink) Old 01-08-2009, 12:59 PM
I think Oreo meant that the resistor is in the engine bay?
post #9 of 15 (permalink) Old 01-08-2009, 01:08 PM
It's located inside the on the passenger side under the glove compartment. Also the blower motor is the same type for all F150 from 1997 to 2003. You will see a plug with some wires on it. Thats the resistor remove the two screws (7mm I belive) that secure to the heater box and remove it
post #10 of 15 (permalink) Old 01-08-2009, 05:08 PM
Yup thats it, but mine (99 350) is under the hood.
NEED HELP: Musty-smelling heater Gord Interior 12 01-03-2013 01:31 PM
NEED HELP: 2004 F150 Heater Problem BigDawg99 Interior 11 12-19-2009 08:38 AM
NEED HELP: Oil Pan Heater tedder57 F-150 2004 to 2008 Forum 3 11-23-2008 09:24 AM
Heater Help BigDawg99 Interior 8 11-08-2008 08:17 AM
