squeak - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 02-07-2009, 04:34 PM Thread Starter
fordfan22's Avatar
squeak
i have a squeak comming from drivers side suspension area, happens when the suspension decompresses and sometimes when turning. i greased everything up somthing it was something simple. not happening though. any ideas? its fairly loud.
fordfan22 is offline
post #2 of 7 (permalink) Old 02-09-2009, 01:45 AM
Might be a ball joint since you said it happens sometimes when you turn. Since Ford didn't think we actually NEEDED to grease them they do go bad after a while. If you have to get them replaced get the ones that have the Zirk grease fittings so you can grease them in the future. If its the ball joints you can go for a temp fix, they have these long needle type things, not sure of the name but you can use them to inject grease thru the rubber covering but it will leave a small hole, like I said its a temp fix.
post #3 of 7 (permalink) Old 02-09-2009, 09:47 AM
tohi2care's Avatar
Cover the hole with something like Sikaflex 291 and it shouldn't be a problem.
tohi2care is offline
post #4 of 7 (permalink) Old 02-09-2009, 09:58 PM Thread Starter
fordfan22's Avatar
all front end ball joints were replaced about 2 years ago. do they go that quick? cause those bastards ain't cheap. could it be anything else? also only happens when its warm. started just before winter, then i took it off roading, and it stopped, figured maybe it was just something stuck, cause it stopped. but now that the weather is warming up a bit its back
post #5 of 7 (permalink) Old 02-09-2009, 11:09 PM
antisway bar rubbing in the bushings maybe?
post #6 of 7 (permalink) Old 02-10-2009, 08:50 PM Thread Starter
fordfan22's Avatar
maybe, i'll check. i ain't no mechanic, i'm just hoping for some ideas on what it might be before i get it looked at.
post #7 of 7 (permalink) Old 07-13-2009, 08:22 PM Thread Starter
fordfan22's Avatar
turns out it was a stabilizer bushing and the axel was shot too. 250 to fix. i was expecting more. pretty happy day for me
Squeak in Engine? Regulator54 Gas Engines 3 02-07-2008 08:45 PM
