What is the best spark plugs to get? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 04-27-2009, 12:54 PM Thread Starter
Ford00XLT's Avatar
Question What is the best spark plugs to get?
What is the best spark plugs to get? i has looking in to the E2 seen on powerblock tv.
Ford00XLT is offline
post #2 of 2 (permalink) Old 04-27-2009, 03:30 PM
Good quality NGKs or the sort. Whatever's cheap but last well. Don't waste your money on marketing ploys.
Unless you're racing your truck or its supercharged, you won't notice a difference between different sparkplugs. Make sure they're in the proper heat range as well, because remember, the hotter the spark the more chance you'll burn a hole in you piston (spark plug length is also critical, all this assuming you go non-OEM and try a different size). Electricity is lazy, so those multi-prong sparkplugs will only work for a bit until they foul up even a bit, then the spark will only jump at the cleanest post anyways. If you're paying for a $50 set of sparkplugs, it can get pretty damn expensive changing them every few months to keep the performance up!
Here's another discussion on them from bc4x4.com: http://bb.bc4x4.com/showthread.php?t...ight=sparkplug . LR
Spark Plugs Silver FX4 Gas Engines 3 08-22-2009 09:45 PM
NEED HELP: spark plugs dpet5 F-150 2004 to 2008 Forum 1 04-26-2009 01:47 AM
SPARK PLUGS dpet5 F-150 2004 to 2008 Forum 1 04-15-2009 12:40 AM
4.6L spark plugs? BCwheeler F-150 2004 to 2008 Forum 3 11-16-2008 07:29 PM
Spark Plugs klewis Gas Engines 2 02-28-2008 05:48 PM
