Cruise not coming on - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 13 (permalink) Old 06-26-2009, 10:19 AM Thread Starter
nf150's Avatar
So, recently the engine light came on and I scanned the code and it came up with a error stating "engine can not complete diagnostic check" Turns out it was a vacum line that came off near the throttle body.
Since this the Cruise will not work. I replaced the worn vacum hose with the same diameter hose and re-connected the hose to the unit.
Some thoughts that I have had:
- do i need a new part ( the little black box that is near the throttle body??? two vac lines attached and an electrical connector???)
- fuses have been checked and appear to be ok.
-engine light has stayed off since re-connecting the new vac line.
Any thoughts would be appreciated!
THANKS
nf150 is offline
post #2 of 13 (permalink) Old 06-26-2009, 12:35 PM
have you tried disconecting the battery to reset everything ? just an idea
post #3 of 13 (permalink) Old 07-20-2009, 09:03 AM Thread Starter
nf150's Avatar
tried the battery disconnect, to no avail. and now I think my truck has an electrical gremlin, the compass, temp gauge will turn on for a moment and then goes off, but it was working fine yesterday!!
so to date:
cruise light will flash on the dash when the main control button is pushed but not remain on. I have looked at the fuses but they look ok.
the temp/compass overhead console has gone out but will flash, I have not looked at the fuse for this.
If anyone can let me know which fuses that control both these it would be a great help.
thanks
nf150 is offline
post #4 of 13 (permalink) Old 07-20-2009, 02:08 PM Thread Starter
nf150's Avatar
should you replace fuses that appear to be ok? WTF!!!! ARGH!!!
nf150 is offline
post #5 of 13 (permalink) Old 07-21-2009, 01:41 AM
have you checked the brake press switch on the master cyl(there is a recall/fsa on these)
post #6 of 13 (permalink) Old 07-21-2009, 09:20 AM Thread Starter
nf150's Avatar
i searched the VIN number from my truck and it lists no recall on the truck? Can you provide the service recall? please
thanks
nf150 is offline
post #7 of 13 (permalink) Old 07-21-2009, 12:48 PM
Any Ford dealer should be able to help you with that recall it was a major issue causing under hood fires
post #8 of 13 (permalink) Old 07-21-2009, 03:47 PM Thread Starter
nf150's Avatar
apparently the issue was cleared off the ford page, or has been completed on the truck.
thanks
nf150 is offline
post #9 of 13 (permalink) Old 08-18-2009, 03:08 PM Thread Starter
nf150's Avatar
I think I may have found the problem with the cruise, the smallish black plastic box that connects two vacum lines near the throttle body, under the black plastic cover has a small crack in it...
Does anyone know what this part is called, and an approx price on such a unit? I can't read the part number off it as it is so tiny..
Any suggestions and help appreciated!
nf150 is offline
post #10 of 13 (permalink) Old 08-18-2009, 03:50 PM
do you have a pic of the part?it sounds like the dpfe sensor(has 2 hoses & a 5pin connector and shouldn't affect the cruise)
MEET PICTURES: Kingston meet coming up fordtough.ca Québec 1 09-13-2008 05:28 AM
