Transmission shifting problem - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 07-18-2009, 12:38 AM Thread Starter
lilbruicer's Avatar
Send a message via MSN to lilbruicer
Exclamation Transmission shifting problem
Hello
Anyone out there know why my transmission is shifting hard it only shifts hard only when you are going up hill and it kicks down to a lower gear i took it to my mechanic to see if there was somthing wrong with the transmission he said that it was fine could it have something to do with tuneup or fuel problems because it is a brand new rebuilt tranny with a moter that has 250000 kms on it could it have something to do with that. if anyone knows what it could be please email back
Thanks for your time
lilbruicer is offline
post #2 of 7 (permalink) Old 07-18-2009, 01:14 AM
I assume you've checked the fluid level. Is the OD light on your shifter flashing?
post #3 of 7 (permalink) Old 07-18-2009, 06:59 AM
swackly's Avatar
The speed sensor where to speedo cable goes in to the transmission I had a 1991 an it screw up and the trans shifted really hard
swackly is offline
post #4 of 7 (permalink) Old 07-19-2009, 04:40 PM Thread Starter
lilbruicer's Avatar
ya i checked the od shifter and its not blinking because that what my mechanic said too. is to check that
thank you
post #5 of 7 (permalink) Old 07-21-2009, 01:52 AM
which truck is it?if it's the 94 did they use the correct fluid in it(using mercon sp or merc syth will cause high down shift pressures,merc 3 should be used or merc v)also if you have access to a scan tool check line press(epc)should be around 35-50 at idle and boost to 100 in gear,most common concern even on rebuilt is sticking solonoids.
post #6 of 7 (permalink) Old 07-25-2009, 12:10 AM Thread Starter
lilbruicer's Avatar
its the 97
post #7 of 7 (permalink) Old 11-13-2009, 12:29 AM
Could you give me some more info about this? I have an '02 with what seems to be the same problem. Sure love to fix it.
EmmEff is offline
What Transmission do you have? fordtough.ca Driveline and Transmission 34 04-04-2010 11:00 AM
Shifting Bliss. canadian.bacon Ranger Forum 21 08-18-2009 10:06 PM
Transmission problem lilbruicer F-150 1997 to 2003 /04 Heritage Forum 5 03-27-2009 04:03 PM
E40D erratic shifting problem SOLVED finally ronhrob Super Duty Forum 1 06-23-2008 03:23 PM
What Transmission? Disposable-Hero F-150 Pre-1997 Forum 5 01-23-2008 12:26 AM
