Exhaust leak - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 22 (permalink) Old 07-20-2009, 06:43 PM Thread Starter
Exhaust leak
On a recent trip my exhaust started leaking, the bolts that go from the manifolds to the rest of the exhaust let go. Well only one let go but I am replacing all of them because the old ones are almost completly gone between the flanges. My problem now is I can't get the portion that is left in the manifolds out. If I pull the manifolds off would a shop be able to get them out or do I need new manifolds as well? Is it even possible to remove the manifolds with the motor in place? The bottom bolts look like they are gonna be a P.I.T.A
Oh yeah it's a 97 f-150 4.6 v8
post #2 of 22 (permalink) Old 07-21-2009, 12:53 AM
97 - 04 2v motors were known for the exhaust manifold studs letting go particularly at the rear of the manifold, the bottom bolts are a little PITA but it can be done with the motor in the truck through the wheel well , [remove the inner fender + wheel], soak the studs with penetrating oil for a few days it should make removing the manifold easier, and once removed the broken one you have should have enough to grab onto to get it out
post #3 of 22 (permalink) Old 07-21-2009, 02:27 AM Thread Starter
I'm soaking them in liquid wrench now then it's going to a mechanic. I'm in a little over my head on this one, especially since most of my tools are in storage. Thanks for the help anyway.
post #4 of 22 (permalink) Old 07-21-2009, 09:33 AM
yea mines got the same problem one reason i bought headers.... havent tackeled the problem yet maybe this winter sort of sounds like an old farm truck with the engine tick lol
post #5 of 22 (permalink) Old 07-21-2009, 10:48 AM Thread Starter
Mine is extremly loud, scared me when it let go.
post #6 of 22 (permalink) Old 07-21-2009, 12:42 PM
When I did mine I sprayed them twice a day for a week and they came out no problem
post #7 of 22 (permalink) Old 07-22-2009, 05:38 PM Thread Starter
So after deciding to do it myself I am having a couple issues lol
I picked up a set of manifolds at pick n pull, the nuts (with studs still attached to the nuts) came off with a 13mm socket no problem or liquid wrench. But on my truck 13mm is too big so is 12 and 11mm too small. Tried 1/2" too big tried 7/16" too small. Am I missing something or do I just take the die grinder to the nuts then remove the studs?
Issue #2 Is there a trick to removing the manifold to collector studs from the manifold? (whats left of them anyway)
Thanks in advance
post #8 of 22 (permalink) Old 07-23-2009, 12:44 AM
Your manifold bolts/nuts may have rust and crap on them I do believe the proper size is 13mm when I did mine I used my bolt outs http://www.sears.com/shc/s/p_10153_1...2166000P?mv=rr they came in really handy for that job, and for the collector nuts I have an impact so it wasn't an issue for me but if you have to just cut them off or try a breaker bar
post #9 of 22 (permalink) Old 07-23-2009, 01:32 AM Thread Starter
I'm gonna try those bolt outs, thanks. The problem with the collector studs is that there isn't much left of them to grab on to. I'll take a pic and post it.
post #10 of 22 (permalink) Old 07-23-2009, 01:39 AM Thread Starter
[IMG][/IMG]
Oil Leak on 91 f150 Waborita92 F-150 Pre-1997 Forum 12 05-18-2009 03:36 PM
Water Leak!! Cooker Ranger Forum 10 11-24-2008 04:02 AM
Major Coolant Leak...please help. Elgando Super Duty Forum 1 05-23-2008 11:25 AM
2001 Supercrew exhaust/2006 exhaust erico88 F-150 1997 to 2003 /04 Heritage Forum 2 12-07-2007 06:17 PM
Water Leak bat052 F-150 2004 to 2008 Forum 2 11-26-2007 08:35 PM
