Heater Fan Speed - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 08-27-2009, 11:00 PM Thread Starter
Heater Fan Speed
Hi
Just replaced my heater resistor as the fan would only operate on high speed. Now I have the fan blowing in all positions however there only appears to be 3 speeds Is that correct even though there are 4 positions. One speed at LO a higher speed on the next 2 positions (sounds the same) and then the highest speed on HI.
Could someone confirm if this is correct or could I have a faulty resistor.
2000 F150 XL Manual Heating Controls 4.2 V6
Terrier
terrier2006 is offline
post #2 of 2 (permalink) Old 08-28-2009, 03:38 PM
if the resistor burnt out it could of damaged the wiring or the switch itself(known concern of switch conn melting)
Heater problem RedFlareside4X4 F-150 1997 to 2003 /04 Heritage Forum 14 11-11-2010 03:13 PM
NEED HELP: fan cowling albertaboy Gas Engines 4 02-08-2009 12:16 PM
Heater Help BigDawg99 Interior 8 11-08-2008 08:17 AM
Interior fan speed switch Fordwheeler Interior 4 10-21-2008 11:55 AM
electric fan Jensen Gas Engines 3 07-18-2008 05:56 PM
