cats ???? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 09-14-2009, 09:49 PM Thread Starter
cats ????
Would replacing my 4 cats on my 98, f 150,4x4, 4.6 ,5 speed benafit me at all ?? no promblems with the cats now just want to know ?
joetalon is offline
post #2 of 9 (permalink) Old 09-14-2009, 11:14 PM
hi flow cats would help your performance but not by a huge amount
post #3 of 9 (permalink) Old 09-15-2009, 01:11 AM
it would make your truck lighter because your wallet would be thinner!jk you would have to make sure they are smog legal in your area.
post #4 of 9 (permalink) Old 09-15-2009, 03:57 AM
just move to alberta theres no e test out there
post #5 of 9 (permalink) Old 09-15-2009, 04:05 AM
fordfan22's Avatar
or manitoba..that i know of.. but your probably better off not moving here, your truck will just get stolen anyways
fordfan22 is offline
post #6 of 9 (permalink) Old 09-17-2009, 01:31 AM
my bf cut my secondarys out and just knocked the junk out of the primarys. I get way better fuel milage now and my truck sounds alot better, mind ya i have a flow pro mx muffler too. But i live in Alberta so there is no e test. but ya it did help my 2003 f150 4.6 alot. it was quite gutless before and now it's good.
Andertr is offline
post #7 of 9 (permalink) Old 09-17-2009, 03:47 PM
only problem on a 04+truck would be they have upsteam/downsteam o2sensors,so you would have to install simulators or you would have a check eng lamp on,besides when they bring in mandatory testing here(wont be long)your screwed!
post #8 of 9 (permalink) Old 09-18-2009, 09:53 PM
Actually he bought some bungs from the local muffler shop and put the sensors back in. Also if you have a chip you can clear any codes
Andertr is offline
post #9 of 9 (permalink) Old 09-19-2009, 04:16 PM
this is true but the lamp will keep coming on because the rear sensors are a catalist monitor so if it sees the rears in sync with the front will trigger a catalist monitor code and posible failure effects mode(reduced power output)
The cats are gone Roadwarrior Intake, Exhaust 10 08-27-2008 05:30 PM
