oil - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 09-15-2009, 04:12 AM Thread Starter
fordfan22's Avatar
oil
i was wondering, but couldn't find a thread on the site about it. is it bad to switch back and forth from conventional oil to synthetic? or does it not really matter? thanks in advance
fordfan22 is offline
post #2 of 4 (permalink) Old 11-14-2009, 03:22 PM
Once you switch, you should generally stay with what you are using, there are marketed mixes of conventional oil and synthetic, but its better with one or the other, i recommend synethetic and lighter oil for higher milege engines, myself i have a 97' 4.6 4WD and i use Castrol Synetec 5w-50, works like a charm, plus you can go a bit further with out changing your oil.
Raymond is offline
post #3 of 4 (permalink) Old 11-14-2009, 04:29 PM
From what I've read in a lot of different places, it really doesn't matter if you switch. That's a bit of an urban legend. As far as I know, there's nothing "magic" about synthetic oils. They're just basically a higher quality of oil. For my purposes, the main advantage is that synthetics have a little better cold weather performance. If I lived in a mild place like Vancouver, I probably wouldn't spend the extra $$$.
There are some good FAQs around on manufacturers's websites like Mobil and Castrol. Just google "synthetic oil FAQ".
post #4 of 4 (permalink) Old 11-15-2009, 06:59 PM
Blue Oval's Avatar
I'm no expert, but I agree with b4000.
Both are oil, which is there to lubricate and protect engine components. The biggest difference is the method in which they are manufactured - conventional comes out of the ground, whereas synthetic starts in laboratory.
I see no reason why you can't run syn in the winter when you'll reap the benefits and go conventional in the summer to save a couple bucks. On the other hand, if you can afford it, why not reap the benefits all year round?
Blue Oval is offline
Oil changes, who does them and who gets them done? fordtough.ca Truck/SUV Talk 97 11-22-2013 03:47 PM
What Oil? fordtough.ca Gas Engines 28 03-14-2010 10:01 PM
What oil do you use? Smokefan Gas Engines 23 02-18-2008 08:53 PM
