2002 f150 shift on the fly - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 12 (permalink) Old 09-28-2009, 10:50 PM Thread Starter
i have a manual shift 4x4 the shift on the fly no longer works. i need to be at a dead stop or else when the vaccum actuator engages there is a grinding.
Haley-Special is offline
post #2 of 12 (permalink) Old 09-28-2009, 11:42 PM
you could have a shift fork broken in the front diff,is a common concern.
post #3 of 12 (permalink) Old 09-29-2009, 12:18 AM Thread Starter
hello,
if that were the case would the 4x4 work at all??
post #4 of 12 (permalink) Old 09-29-2009, 12:33 AM
they tend to brake one tab off the fork causing it to only push on one side of the collar,i've also seen the vacc lines behind the battery rot apart causing this same issue.
post #5 of 12 (permalink) Old 09-29-2009, 12:41 AM Thread Starter
ya i checked the vaccum lines, i can see the acctuator working when my friend puts it in 4 wheel drive. if there were a electrical prb in the t case would that put the service engine light on?? could a problem with the vaccum lines affect the shift on the fly, although the 4x4 will still work if i do it from a dead stop??
post #6 of 12 (permalink) Old 09-29-2009, 01:26 AM
do you have a manuel stick t/case?if you do the only elec conn will be the range sensor,if the front diff lever is moving full throw the fork could be at fault,try moving the diff lever manuelly while turning wheel it should engauge smoothly.
post #7 of 12 (permalink) Old 09-29-2009, 01:31 AM Thread Starter
what about the electromagnetic cluch in the transfer case, even the manual ones have it dont they?
post #8 of 12 (permalink) Old 10-01-2009, 12:12 AM
yes they do have a electro syncroniser clutch,check fuses 53 in cjb(under dash)and bjb fuse#37,then check for voltage on shift to electro clutch if batt voltage then check resistance of clutch to ground(should be aprox 1000ohms),but if your getting a grinding in diff on engaugement i would be checking that first.
post #9 of 12 (permalink) Old 10-01-2009, 01:23 AM Thread Starter
would there be a service engine light on if there were an electrical prb in the T case?? will a scanner help at all??
post #10 of 12 (permalink) Old 10-01-2009, 03:50 PM
you won't have a check eng lamp on but there may be t/case codes in the gem module(p1804-1891)that may help to diag.if you need help to interpret codes feel free to pm me.
shift kit truckman79 Driveline and Transmission 6 05-17-2009 02:22 PM
Clunk when I shift into 4 hi Silver FX4 Driveline and Transmission 6 02-28-2009 03:25 AM
shift kit? canadian.bacon Ranger Forum 4 12-09-2008 09:33 PM
