Bypass/overide for highbeam/foglights ?? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 15 (permalink) Old 12-09-2009, 08:40 AM Thread Starter
smokum's Avatar
Question Bypass/overide for highbeam/foglights ??
Does anyone know of a bypass or overide to eliminate the highbeam/foglight cancellation on a '99 F150 Lariat ??
Thanks,
Greg
smokum is offline
post #2 of 15 (permalink) Old 12-10-2009, 12:25 AM
If I understand you properly you want to be able to have your highs on with your fogs at the same time?
I'm pretty sure I've seen this issue answered on another forum. From what I remember you have to modify something inside the headlight switch.
I'll try to dig it up.
post #3 of 15 (permalink) Old 12-10-2009, 12:33 AM
I had this done on my 00' F150, my buddy wired it up for me so that didn't require modification to the headlight switch. He connected the foglights to the highbeam trigger on the headlight bulb using a relay so that when I turned on the highbeams power was still supplied to the foglights. I have this done on my 05' FX4 as well. SUPER BRIGHT.
post #4 of 15 (permalink) Old 12-10-2009, 01:20 AM
Search out the Bambi Mod. i've seen how to do this on the 04-08 series on another forum, not sure if the 97-03 is similar.
post #5 of 15 (permalink) Old 12-10-2009, 01:33 AM
I checked on the Bambi mod and so far have not found one for the 97-03s. Only thing I could find was this thread.
http://www.svtlightnings.com/svt/how...s/foglamps.htm
But from what I read it doesn't say if this will allow the Highs with the Fogs.
post #6 of 15 (permalink) Old 12-10-2009, 09:49 AM Thread Starter
smokum's Avatar
Thank you for your responses guys...... I'll take a look at the link and see what there is to see, and do some more searching.
Was kinda hoping for an aftermarket add on/in but I guess I've got some reading to do, lol....
-Greg
smokum is offline
post #7 of 15 (permalink) Old 12-10-2009, 08:21 PM
I'm just wondering about the concept of having both hi and lo beams on at the same time? Don't the lo beams shut off for a reason? I mean, sure, it's going to be brighter, but does that actually help you see better? If you're driving fast enough to need to use the hi beams (so you can see further), then what difference does it make seeing stuff closer to the front of the truck? At those speeds, if something is so close that you'd only see it in the lo beam area, I wouldn't think you'd be able to hit the brakes in time anyway, and wouldn't that extra bright area sort of blind you to the dimmer light of your hi beams further ahead, where you actually would have a chance of stopping or avoiding an obstacle?
Does that make any sense, or maybe I just don't get how it works?
post #8 of 15 (permalink) Old 12-10-2009, 11:52 PM Thread Starter
smokum's Avatar
I think you misunderstand, and its has nothing to do with higher rates of speed.
I'm asking about modifying to have the High beams AND factory "fog lights" on at the same time.
I live in the boonies where deer, fox, and coyotes are rampant, and any street lighting non existent, so its quite a difference in overall viewing of the roadway when the fog lights cancel out if you choose to operate the high beams which in turn unnecessarily restrict having an overall brighter view when needed or desired.
Hope that makes sense.... I just got back from surgery today and am still a bit groggy.
-Greg
smokum is offline
post #9 of 15 (permalink) Old 12-11-2009, 12:19 AM
I read on another forum, someone had a friend wire up the fog light power to the high beam power on the headlight in order to use them when the highs are on. Sorry they didn't give any more details.
post #10 of 15 (permalink) Old 12-11-2009, 01:04 AM
That's exactly what I did. I have no idea what my buddy did but I trusted him cause he's an electrician. Took him 10 minutes, hardest part was putting the darn headlight back in place. One of the best mods I've done. I was out snow wheelin' tonight and man does it make a difference.
Bypass oil systems outbacktaz Super Duty Forum 1 07-05-2009 02:27 PM
Where to find OEM foglights for my HD tattooedguy Exterior 5 12-27-2008 07:31 PM
How to bypass the rear solinoid on the Airb Bags MRGADGET Wheels and Tires 0 05-20-2008 10:55 AM
low beams/highbeams and foglights not working myneedforspeed Lighting 0 12-18-2007 11:32 PM
Bypass Oil Filter 98 Ranger Rebel Gas Engines 3 02-10-2007 02:17 AM
