'03 4.6 temp. sensor repair - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 01-02-2010, 03:52 PM Thread Starter
My sensor has given out on me, I've located it on the inside of the left head. However, outside of a custom tool, I see no easy way to remove it.
Has anyone replace this sensor, and if you have, how'd you do it?
Triton is offline
post #2 of 6 (permalink) Old 01-02-2010, 05:03 PM
it should un thread using a open end wrench. put some teflon tape on the new one when you go to put it back in.
post #3 of 6 (permalink) Old 01-02-2010, 11:41 PM Thread Starter
It's on such an angle and with the harness clamp on the far side of the sensor, putting a wrench in there seems quite tight. If I could get the harness off, then an open end wrench would/could be possible, but the clamp/catch is on the far side of the sensor and even tougher to get at.
Triton is offline
post #4 of 6 (permalink) Old 01-03-2010, 01:29 AM
on the inside of the left headlight... if so not sure if its what you mean but pull the 2 tabs on the top of the headlight and it comes out as a complete unit might give you more acces....
if this isnt what you were refuring to sorry not sure exactly where the sensor is
post #5 of 6 (permalink) Old 01-03-2010, 07:19 PM
i used a open end wrench to do it.... take ur time it will get done.
post #6 of 6 (permalink) Old 01-04-2010, 12:45 AM
take the alternator out of the way and you have lots of room.
2006 FX4 whine sound @cold temp. *$%&@ !! 4X4 EH F-150 2004 to 2008 Forum 41 01-22-2015 11:20 PM
COMPASS/TEMP GAUGE COMPUTER nf150 F-150 1997 to 2003 /04 Heritage Forum 4 09-04-2009 02:51 PM
Reverse Sensor going off for nothing RJohn357 F-150 2004 to 2008 Forum 10 01-27-2009 09:31 PM
Tranny Temp sensor Roadwarrior Driveline and Transmission 10 08-17-2008 03:41 PM
camshaft sensor zarbatad Super Duty Forum 1 12-08-2007 01:35 PM
