Transmission cooler line problem - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 01-31-2010, 01:59 PM Thread Starter
Hi guys,
I have a cooler line probs on the 99 F150 4.6l. The entire lines (3) are worth $ 300.00. Since I don't use the truck and only start it for now ( to ensure the engine don't seize), I would like to fix it cheaper... Is there a way to simply unplug the cooler until I change the line ?
Thanks for you help
blueghost is offline
post #2 of 6 (permalink) Old 02-01-2010, 01:54 PM
connect a hose to the lines so it bypasses the cooler, just don't drive it for more than a mie or two on normal roads.
ronburgundy is offline
post #3 of 6 (permalink) Old 02-02-2010, 10:09 AM
swackly's Avatar
Just use high pressure gas line to connect the roten spots and double clamp it. Older ford have pieces from factory like that.
swackly is offline
post #4 of 6 (permalink) Old 02-02-2010, 04:15 PM
just repair the lines with hp oil/fuel compatable hose and don't forget to flare the line ends to help retain the hose.
post #5 of 6 (permalink) Old 04-25-2010, 11:07 AM Thread Starter
Thanks for your answers
I don't drive the truck yet, as I need to have an inspection and have some major repairs to do, like the entire exhaust that have to be changed (manifolds, cats, muffler,etc...). For now, I only start it and try to make it move a little.
Is there a loop that can be made between the input / output at the transmission side ? It's a temporary fix, until I have more cash to simply change all the lines at once
post #6 of 6 (permalink) Old 06-29-2010, 12:31 PM Thread Starter
Thanks guys I finally opted to a brand new line... cost me around $170 and it took me around 4 hours to replace it...but it's done It was the upper radiator/lower transmission line. Now,have to very the leak in the power steering. Thanks again for all your advice
Transmission shifting problem lilbruicer F-150 1997 to 2003 /04 Heritage Forum 6 11-13-2009 12:29 AM
Transmission problem lilbruicer F-150 1997 to 2003 /04 Heritage Forum 5 03-27-2009 04:03 PM
INSTALLED TRANNY COOLER.... THE H.P FREAK Ranger Forum 2 01-27-2009 12:41 PM
RELOCATED MY TRANNY COOLER.... THE H.P FREAK Ranger Forum 5 01-15-2009 01:53 AM
