Box removal - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 23 (permalink) Old 02-20-2010, 01:56 AM Thread Starter
xllxll_VIPER_llxllx's Avatar
Box removal
Anyone have a how to or pictures or diagrams on the removal of the flareside box year 2000? Also the length of time it would take?
2003 FORD ESCAPE XLT 4X4
post #2 of 23 (permalink) Old 02-20-2010, 04:05 PM
box side or whole box off frame ?
should be just the 4 bolts (maybe 6) undo the fuel door setup at the rear unplug the tail light harness
and lift it off....
post #3 of 23 (permalink) Old 02-20-2010, 05:20 PM Thread Starter
and lift it off....
Thanks dude..... ya its the whole box... i really dont have to do this but i'm very picky about the care of my truck so i figured that when i repaint the truck this spring i might as well go all the way and remove the box and do the frame and all..... my floors and frame are mint even tho i plow with this truck... i want to keep it that way. Thanks for the info... i didnt think it would be more then 6 bolts on the 6.5 ft bed and since its the flareside and the majority of the box is fiberglass it would be to heavy
post #4 of 23 (permalink) Old 02-20-2010, 07:06 PM
This is from the 1998 Ford service manual should be the same as your truck
Pickup Bed
Removal
1. If equipped, roll up the tonneau cover.
2. Remove the fuel filler neck screws.
3. Disconnect the tail lamp harness electrical connector.
4. Disconnect the license plate lamps.
5. If equipped, unhook the trailer wiring harness electrical connector from the bumper.
6. Remove the fuel filler pipe to pickup bed clamp.
7. Disconnect the rear axle vent tube from the pickup bed.
8. CAUTION:
Use care not to scratch the pickup bed.
If equipped with a 1.98 m (6.5 ft) bed, remove the bolts.
9. CAUTION:
If equipped with a 2.43 m (8 ft) bed, remove the bolts.
10. CAUTION:
Use body decking protectors over the front corners of the pickup bed to prevent scratches.
CAUTION:
Lifting the pickup bed requires at least two people on each side.
Remove the pickup bed.
post #5 of 23 (permalink) Old 02-20-2010, 07:21 PM Thread Starter
Thank you sir! I'm assuming its held on by 6 carriage bolts? Thanks for the pics!
post #6 of 23 (permalink) Old 02-20-2010, 07:37 PM
The box bolts are a T 50 or T 55 Torx head soak them in oil daily for a week or two prior to removal this should help you get them out with out heat
post #7 of 23 (permalink) Old 02-20-2010, 07:48 PM Thread Starter
Thanks very much for the info.... now i just have to wait for spring! What should they be torqued back to when reinstalling them? i also believe i'd use locktite to keep'em from coming loose.
post #8 of 23 (permalink) Old 02-20-2010, 08:03 PM
I just went thru my 97-00 Chilton manual and i can't even find how to remove the box in there much less the torque specs. I would torque em till they break...then back off 1/2 turn
post #9 of 23 (permalink) Old 02-20-2010, 08:09 PM Thread Starter
lol thanks for the advice
post #10 of 23 (permalink) Old 02-20-2010, 09:04 PM
I would say 45-55 FT Pounds should be enough
Panel Removal macs07 F-150 2004 to 2008 Forum 2 01-20-2010 07:45 PM
Oil filter removal ninjabill F-150 2004 to 2008 Forum 15 12-20-2008 12:57 PM
Bed Rails- Removal? xtylerx F-150 2004 to 2008 Forum 3 02-26-2008 02:17 AM
New TSB for 5.4 plug removal. Irish FX4 Sticky Tech/How to Section 2 02-16-2008 04:36 PM
Headlight Removal??? white4by4 F-150 2004 to 2008 Forum 5 02-05-2008 11:40 PM
