97 high idle stalls - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 12 (permalink) Old 03-01-2010, 06:02 PM Thread Starter
97 high idle stalls
bro in law bought a 97 reg cab short box its auto with the 4.2L
i havent had the chance to look at it yet but it apparently high idles at a stop sign/light and sometime the exact oposite it will stall out
like i said i havent had a chance to look at it yet or listen to it run, anyone have any ideas ? sort of seems to me like a vacume problem.....
post #2 of 12 (permalink) Old 03-01-2010, 07:08 PM
could be the iac valve also.
post #3 of 12 (permalink) Old 03-02-2010, 07:37 PM Thread Starter
thanks shelby will have a look and see if i cant find the problem drove it into the shop tonight and i ran great got to get time to look at it
post #4 of 12 (permalink) Old 03-05-2010, 07:39 PM Thread Starter
well pulled the truck into the shop couldnt get it to high idle at all but when in gear it almost stalls out and surges from stall point to idle rpm's
pulled the IAC off had a look it seems to be working proper cleaned and lubed up put back on didnt make a difference found a small vacum leak on the passenger side in a main conection fixed truck still does the same thing, chck engine light was on also removed battery terminals cleaned and to reset the computer fired back up no change check engine light was out for about 2-5min of running then came back on.... hope to get a scan tool from a buddy and plug it in to get some codes....
it idles fine in park and neutral does its stall thing when in gear when reved up or driving there doesnt seem to be an issue
anymore idea's ?
post #5 of 12 (permalink) Old 03-08-2010, 05:12 PM Thread Starter
p1538
p1537
are the codes... searchin the net but everyone seems to have a different opinion... from vacume by the battery to a part on the back of the intake
post #6 of 12 (permalink) Old 03-08-2010, 08:40 PM
Dank_44's Avatar
check this site out v6f150.com it is devoted to those engines
P1537 - Intake manifold runner control stuck open (bank 1) - While the engine is running, the PCM detected the IMRC bank 1 to be out of its designated spec. Check to see if the valve is stuck open.
P1538 - Intake manifold runner control stuck open (bank 2) - While the engine is running, the PCM detected the IMRC bank 2 to be out of its designated spec. Check to see if the valve is stuck open.
Dank_44 is offline
post #7 of 12 (permalink) Old 03-09-2010, 12:20 AM
check the imrc valve vacc lines at rear of lower intake(they like to melt)also see if you can manuelly move the imrc lever(be careful they are under spring pressure)to see if plates are seized.
post #8 of 12 (permalink) Old 03-09-2010, 01:34 AM
Originally Posted by LayinHp View Post
p1538
p1537
Yeah the PCV elbow back there can collapse. PITA to get to though. When I had the top of the motor off a few years ago I noticed mine looked like an hourglass shape restricting air flow.
post #9 of 12 (permalink) Old 03-10-2010, 10:36 AM Thread Starter
thanks joined the site but "still" waiting on being alowed to post... and not many issues that i can find there with IMRC
re looked at vacume lines slight leak pulled apart and re-sealed all i had was grease it worked but truck still ran like ass (after running the leak re-apeared like an over pressure leak) and CEL still came back so we pulled the intake off, its been off before (note he just bought the truck a month ago) get the intake off and the IMRC's seem to work properly for what we can tell they move freely and when moved create vacume in the lines that run to the intake
side note the intake and runners leading by the IMRC are carboned up pretty good but the back runner closest to the IMRC is spotless....
not sure where to go now besides a new gasket a clean up of everything and re-assemble... hate to put it back together and still have the bad idle problem
also the IAC control on top of the intake is makeing a loud buzzing noise when ingaged it seem to be working but not well
post #10 of 12 (permalink) Old 03-10-2010, 11:45 PM Thread Starter
still no luck at the v6f150 site going to give up.....(still waiting for an aproval to post)
put everthing back together this afternoon the IMRC's both work and hold there vacume found that the intake gasket was new and could have been leaking from bolts not so tight its a felpro gasket heard bad things with them in the 4.2L's but ive had good luck with them in the past in my 2.9L's that ive had apart and a 5.0L
reused the gasket and blue siliconed it the idle control valve will be replaced it wasnt throwing a code but it sounded sick when actuating (or not) and same problem idle with engine stumbling in gear although it wasnt as bad and when messing around with the IAC it would go away or comeback even at one point unplugging the IAC and the engine ran like a dream... hope its fixed need to get other projects in the shop
Engine stalls, hesitates uphill only! Alan001 Gas Engines 8 03-14-2010 06:50 PM
idle/RPM lonerangerxlt F-150 2004 to 2008 Forum 5 02-16-2010 12:45 AM
Idle Problem countryboy Gas Engines 10 01-20-2010 02:31 AM
High Insurance? F150 F-150 2009 to 2014 Forum 8 05-21-2009 11:13 PM
NEED HELP: high idle CKM Ranger Forum 8 12-09-2008 12:31 AM
