Driver's side power window - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 03-18-2010, 09:08 PM Thread Starter
2002 F150
The drivers window goes down fine, but when it goes up it reaches a certain point then slows to a stop. does this sound framiliar to anyone??
Haley-Special is offline
post #2 of 6 (permalink) Old 03-19-2010, 12:49 AM
it could be that the motor is getting weak,but you can try to lube the felt glass runs on the door with silicone spray first.
post #3 of 6 (permalink) Old 03-19-2010, 07:40 AM Thread Starter
i lubed the tracks and regulator guides, the window seems to get cockeyed when it goes up.
post #4 of 6 (permalink) Old 03-19-2010, 03:45 PM
you could have a broken glass guide on the regulator track,take your door panel off and inspect.
post #5 of 6 (permalink) Old 03-31-2010, 12:12 AM
Originally Posted by Haley-Special View Post
2002 F150
I'm having a similiar problem with my drivers window, sometimes it wont go down. But if I toggle the switch up then down several times very vigorously it will work, Of course this only happens at the timmies drive through. LOL.
PimpMy98 is offline
post #6 of 6 (permalink) Old 03-31-2010, 12:56 AM
Sounds like you need the run channel replaced
Power Window Problem TowRig Audio and Electronics 2 10-09-2009 08:47 PM
Power Window Mod Oreo Sticky Tech/How to Section 0 08-01-2008 11:39 AM
Driver's side wheel bearing MRGADGET Wheels and Tires 14 04-04-2008 06:28 AM
power window wiring nnik F-150 Pre-1997 Forum 9 03-01-2008 03:39 PM
