99 Lost daytime running lights - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 04-03-2010, 12:35 PM Thread Starter
ml878us's Avatar
Unhappy 99 Lost daytime running lights
Hi guys, its been a while, but I have been busy with house projects instead of truck projects ;-)
I went out for a coffee last night, and when I started the truck the headlights stayed off until I actually turned the switch, then worked normally
Given that they worked fine on my way to work on Thurs, I can only assume a wire SOMEWHERE has either corroded off a contact, or burned thru.
Before I waste a ton of time trying to trace it on my own, does anybody have prior experience with a similar problem and can shorten my list of places to look?
TIA
ml878us is offline
post #2 of 3 (permalink) Old 04-06-2010, 01:47 AM
Check the DRL module, it may be cracked letting moisture in causing a short or corrosion.
It should be behind the front bumper, rectangle shaped thing, you should be able to see it from the drivers side wheel well. Mine was cracked but it did the opposite, the lights would not turn off even in the off position.
post #3 of 3 (permalink) Old 04-06-2010, 04:06 PM
common concern is for the elec conector to get all corroded on the drl module.
What Head Lights Bulbs are you running? fordtough.ca Lighting 25 07-20-2012 01:11 AM
Day Time running lights Waborita92 Ranger Forum 5 01-02-2010 06:33 AM
Lost contacts Lone Ranger British Columbia 1 08-30-2009 05:35 PM
Daytime running light module stormy663 Ranger Forum 0 11-11-2008 12:09 AM
