Go Rhino! Grillguard Help - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 05-17-2010, 10:52 PM Thread Starter
Hello. Today I purchased a second hand Go Rhino Grillguard for my 1999 LD F250 (7 Lug). It is in very good condition and with a good wash/polish/wax will look like new. It was supposedly for a 1997 to 2003 F150. The fellow I purchased it from said it was on a 2000 F150.
I held it up and it indeed looks model/year correct.
I think though I am missing a couple brackets. I did get a bag of bolts and there are 2 brackets that look like they attach to the grillguard and go through the gap between the grill and bumper (although they seem to rub top and bottom).
But I think I am missing some sort of bottom brackets. Is there a bracket that goes under the factory tow hook and bolts to the bottom of the grillguard or something? . There are 2 holes on each side of the grillguard and it measures about 25 1/2 inches between the two uprights.
If someone has one of these could you please take a look at you rig? Or maybe post a couple pics of the mounting. With a bit of time I'm sure I could fab a couple up but need somewhere to start. Thanks.
gpguy is offline
post #2 of 6 (permalink) Old 05-18-2010, 05:00 PM
jmc
jmc's Avatar
Here is a link to a PDF file of the instructions. http://muestras.netcommerce.com.mx/b...les/3363-i.pdf
Regards,
Jean Marc Chartier
Warn XD900i E-fans, M5OD w/ Hurst short throw, Procharger @15psi, Troyer tuned.
Swap notes 4.6 to 5.4; http://www.f150online.com/forums/art...ml#post3570245
jmc is offline
post #3 of 6 (permalink) Old 05-18-2010, 08:05 PM Thread Starter
Actually I found that late last night at the Go Rhino! website too. Thanks
gpguy is offline
post #4 of 6 (permalink) Old 06-01-2010, 01:28 PM
01f150's Avatar
I know on my 01 f150 I added the bullbar and I had to remove the factory tow hooks to bolt it on. Kinda sucks but I don't offroad it so....
01f150 is offline
post #5 of 6 (permalink) Old 06-01-2010, 10:02 PM Thread Starter
Actually I ended up fabricating brackets that turned out quite good. I was able to keep my tow hooks too.
gpguy is offline
post #6 of 6 (permalink) Old 07-13-2010, 02:04 PM
01f150's Avatar
I would love to see the pics.I'd like to find a way to use my tow hooks again as well.
01f150 is offline
Line X/Rhino Liner ineresting Question Writerz Block Ranger Forum 7 03-30-2009 03:55 AM
Rhino or Submarine? Fordwheeler Off Road 6 10-18-2008 05:03 PM
