Heater/AC controls - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 06-28-2010, 07:27 PM Thread Starter
stormy663's Avatar
Heater/AC controls
I am having some minor issues with the control settings for the heater/AC in a 01 F150 XLT. The indicated settings don't seem to correspond that what actually happens .. for example, when I select panel/floor, I get AC. when I select panel, I seem to get panel/floor. I am pretty sure that it is a standard connector at the switch end .. that leaves connections at the other ends. Any suggestions?
Doug
01 F150 XLT
00 F350 Superduty
98 Explorer Limited
stormy663 is offline
post #2 of 8 (permalink) Old 06-29-2010, 12:57 PM
Sounds like the Blendoor actuator in the heater box needs replacing
post #3 of 8 (permalink) Old 07-10-2010, 07:49 PM Thread Starter
stormy663's Avatar
Is this part available after market or do I have to go to Ford? Estimated cost??
Doug
01 F150 XLT
00 F350 Superduty
98 Explorer Limited
post #4 of 8 (permalink) Old 09-03-2010, 09:58 AM
nf150's Avatar
I am having a problem with my 02 F150 XLT 5.4L engine, the fan speed seems to be only working on high. I have looked at the fuse panel but everything seems fine. IS there any other fuses that I may be missing?
nf150 is offline
post #5 of 8 (permalink) Old 09-03-2010, 10:51 AM
Sorry I missed this post the part is a ford only one as far as I know but involves removing the dash because the broken part is in the heater box
post #6 of 8 (permalink) Old 09-03-2010, 03:54 PM
i would check the vaccuum supply to the mode door actuator first(open glovebox will be on the left)
post #7 of 8 (permalink) Old 09-03-2010, 04:14 PM Thread Starter
stormy663's Avatar
I will check it out.
Doug
01 F150 XLT
00 F350 Superduty
98 Explorer Limited
post #8 of 8 (permalink) Old 09-03-2010, 10:53 PM
Before you buy a new switch, check the knob to make sure it's rotating and the stem is too. Mine had the flat spot rounded off (guess I'm too hard on it) .couple of 1/4" toothpicks wedged in the hole and the stem and back to normal...Ogre
Ogre is offline
Heater fan LayinHp Super Duty Forum 6 01-04-2010 12:01 AM
BLOCK HEATER MississaugaRanger Ranger Forum 30 03-07-2009 12:28 AM
Steering wheel controls Roadwarrior Audio and Electronics 2 12-06-2008 09:15 PM
Heater Help BigDawg99 Interior 8 11-08-2008 08:17 AM
Climate Controls alpine Interior 7 12-21-2007 01:41 AM
