plug truck in - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 12-13-2010, 05:12 AM Thread Starter
Angry plug truck in
i am going to make sure to plug my truck in at night did not start this morning and will be bying a new battery its about 4 years old
gilligan is offline
post #2 of 3 (permalink) Old 12-13-2010, 09:08 AM
Have you got a battery warmer? That really helps. Battery capacity drops with temperature, as does its ability to take a charge. I spliced mine in with the block heater cable, so there's only one plug to connect.
Because the battery is warm, it will deliver more current when you start. Once the engine is running, the battery will also take a charge better, because it's still warm. I think that will also help the battery to last longer.
Plus, check your electrolyte level. It should be over the top of the plates. If it's low, add a bit of distilled water.
post #3 of 3 (permalink) Old 12-13-2010, 09:28 AM Thread Starter
i put a new battery in mine was almost 8 years old so it had its live.
gilligan is offline
Would this plug in? 4x4truckguy Lighting 6 09-23-2010 09:52 AM
Successful plug change. :) Irish FX4 F-150 2004 to 2008 Forum 3 08-16-2010 10:39 PM
Spark Plug Types BigDawg99 F-150 2004 to 2008 Forum 18 07-11-2009 05:00 PM
spark plug help Grizzly F-150 2004 to 2008 Forum 7 10-05-2008 12:16 PM
New TSB for 5.4 plug removal. Irish FX4 Sticky Tech/How to Section 2 02-16-2008 05:36 PM
