engine swap - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 12-19-2010, 06:53 AM Thread Starter
Talking engine swap
i have a 4.2 in my 97 but would like to put a v8 in it to pull my trailer i am not sure if this can be done because of all the computer in the truck has anyone done this or would it be better to change my whole truck thanks my camper is a 27 foot.
gilligan is offline
post #2 of 8 (permalink) Old 12-19-2010, 01:39 PM
Anything can be done with the right amount of time, money and patience. However a 27 foot trailer weighs a good bit? Buying a new truck would be A LOT less headache IMHO
post #3 of 8 (permalink) Old 12-19-2010, 01:45 PM
If I where you I'd do some shopping around for a v8 truck, as to swap in a v8 to the 4.2 your gonna need alot of time, as all the wiring will be different and the computer, good luck
post #4 of 8 (permalink) Old 12-19-2010, 02:51 PM Thread Starter
thanks guys i was just wondering i dont pull to far so i should be ok if i di an engine swap i might put in a newrt 4.2 i m not sure till what year i can go if i really need someone to pull my camper very far i will borrow a freinds truck
gilligan is offline
post #5 of 8 (permalink) Old 12-19-2010, 04:20 PM
in the long run it would probly be cheaper to put in an older 302 carbed...
either that or find a wrecked 2000-2003 truck with the v8 so you have all the parts you need for the swap
copart.com has a few trucks
post #6 of 8 (permalink) Old 12-20-2010, 01:42 AM
It can be done, but it ain't easy, aside from the v8 motor, you'll at least need the computer, main harness from the donor truck. You'll need to use the bell housing from the v6 for the tranny though, the bell housing on the v8 has a different bolt pattern.
If you aren't pulling that far, it might make more sense to put in 3.73 or 4.10 gears and some type of LS diff and an aftermarket tranny cooler, prolly cheaper and easier.
post #7 of 8 (permalink) Old 12-20-2010, 02:06 AM
you'll also need the Power Distribution box from a V8 truck cause yours is only wired to run 6 injectors. Otherwise you'll have to do what I did and wire 2 injectors directly into the V8 computer
post #8 of 8 (permalink) Old 12-20-2010, 02:15 AM Thread Starter
i think i will stick with my 4.2 for now till this truck really dies and the next truck i will by will be a v8 and of corse will have to be a ford nothing beets a ford
gilligan is offline
Engine swap Wolfsbane F-150 Pre-1997 Forum 8 02-19-2011 05:38 PM
NEED HELP: Engine swap???? spittingcobras Gas Engines 11 03-08-2010 01:32 AM
mazda engine swap..can it be done? camkos Ranger Forum 6 10-19-2009 10:33 PM
4.6 -4.6 engine swap littlebronc Gas Engines 10 06-18-2009 12:09 PM
Engine swap? bluegoose Diesel Trucks 5 04-23-2009 03:44 PM
