Not Holding Sixth Gear while Pulling - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 14 (permalink) Old 05-30-2011, 01:07 PM Thread Starter
97350's Avatar
This ones for those who pull trailers.Does your truck hold top gear while pulling? Mine doesn't although I don't travel above 110kph while pulling.I've pulled a car hauler with two quads on it, a 4 place skidoo trailer and my holiday trailer and as soon as it shifts into 6th the speed starts to drop and the tranny kicks down.My travel trailer is 8500# so I can almost expect it but the others are probably half of that and the truck still downshifts.If I could get it to hold without dropping into 5th it would be great.
I'd like to hear from people with similar trucks.5.4 Max Tows.
2010 150 Lariat Max Tow,Banks Monster Exhaust,Ultra Drifter Wheels
97350 is offline
post #2 of 14 (permalink) Old 05-30-2011, 03:30 PM
I would just put the truck in tow haul mode an go it kicks ouy of 6th ad their is to much of a load on it an they use 6th as like a 2nd over drive gear
post #3 of 14 (permalink) Old 05-30-2011, 08:55 PM
I agree with Matt, if your towing you should use the " tow/haul " mode as it holds your speed better and gives you better grunt when you need it, I have never left it out of tow/haul mode when pulling a trailer. Just easier on the truck and fuel mileage
post #4 of 14 (permalink) Old 05-30-2011, 11:13 PM
rgoulet58's Avatar
I always use Tow Haul with my Toy Hauler which is around 7000lbs loaded with 2 bikes. At 100kph on flat road it runs around 2000 RPM. My old 02 with OD off ran around 3800 RPM at 100kph. I only notice a downshift on hills where it jumps to 26-2800 RPM depending on the hill. I also have the Max Tow.
08 23' RPM Toy Hauler
13 Esacpe (Wife's)
06 Vulcan 900 LT
05 Brute Force 650
2010 F150 SC XTR Max Tow
rgoulet58 is offline
post #5 of 14 (permalink) Old 05-30-2011, 11:57 PM
lol my 05 with the open car trailer, nothin on it & full tank and me in it ...is 9,200 and change. i drive everwhere with OD off. till goin over 110.
post #6 of 14 (permalink) Old 05-31-2011, 09:21 AM
ric_no_k's Avatar
Just picked up my 24' TT and it was a rough drive home for me. Never having hauled something that big it was interesting on the highway. I rarely hit 6th, usually only on a downhill and when I took my foot out of it. The big sail I was towing would request 5th once we were on the flat. I had the same type of experience with my 1400# pop up trailer although not as hard on the hills and I could get it to stay in 6th longer on the flat but it was still shifting more than it was empty. This weekend with the TT I noticed difference between 5th and 6th was only about 500-750rpm. By the sound of it you are not in the power band for the speed when using the smaller trailers. Are you using Cruise Control?
ric_no_k is offline
post #7 of 14 (permalink) Old 05-31-2011, 10:39 PM
Why would you use cruise control when towing ??? Guess you really want to make your tranny work over time, if it's shifting in and out of 6th gear I would not suggest using cruise at all and use your tow/hual thats why FORD put it on the truck
post #8 of 14 (permalink) Old 05-31-2011, 11:02 PM
The truck isn't holding 6th gear because 6th gear isn't designed for pulling. There is a reason that the truck wants 5th. Are you using your tow/haul mode?
post #9 of 14 (permalink) Old 06-01-2011, 12:30 AM
ric_no_k's Avatar
I just wondered if he was, he didn't say he was. I asked because I see people on one of the forums saying "yeah you can pull 11,000 pounds. Dealer said so so you are good to go." or wanting to lemon law a truck over Sync or wondering why they are not getting the EPA ratings when they are doing 75-80mph...
Ric
2010 F150 Screw Royal Red
2006 Honda Odyssey
2005 Fleetwood 240BH
ric_no_k is offline
post #10 of 14 (permalink) Old 06-01-2011, 07:39 AM
Yeah i just ise tow haul an let it max 5th gear an keep speeds below 110kms as camping trailers the tires are not rated for fast speeds most like 110 km/h
Pulling carpet Holdfast Interior 2 08-16-2010 10:43 PM
1999 F150 new battery not holding charge relaychatter F-150 1997 to 2003 /04 Heritage Forum 3 12-23-2009 06:15 AM
Pulling Bin File kidd F-150 Pre-1997 Forum 0 08-22-2009 11:31 PM
Truck Pulling thunderstroke Super Duty Forum 3 08-07-2008 11:57 PM
Up or down pulling a 5er? Canadian GP F-150 2004 to 2008 Forum 20 03-19-2008 02:43 PM
