2009 engine removal - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 11-10-2011, 08:49 AM Thread Starter
2009 engine removal
New to the forum, I'm changing the 5.4l in a 2009 f150 and can shed some light on the procedure if anyone needs help. There is a ton of info on the web up to 2008 and then there there are a lot of misconceptions for the 10 generation. Mainly, you DON'T have to lift the cab or cut any rad supports. Around 23 hrs of labor though so it's not for the meek. Motor is out and new (used) is on it's way to me. I'll post more as it develops.
kmacwelding is offline
post #2 of 6 (permalink) Old 11-10-2011, 08:57 AM
5pointslow's Avatar
curious as to the reason for engine swap.
5pointslow is offline
post #3 of 6 (permalink) Old 11-10-2011, 09:20 AM Thread Starter
Seized motor. Heavy towing, poor maintenance, the owner ignored an engine noise (I didn't hear it so I can't describe it) for a couple months. There was a lot of debris on the pickup screen but that could have happened as the connecting rod bearings started to disintegrate. My guess is the oil pump failed or the pickup screen clogged (chicken or the egg?). It all started with a general lack of respect for the vehicle. Some people like to turn the key and go or write checks when that doesn't work. Oil change intervals are important and have to be respected.
post #4 of 6 (permalink) Old 11-11-2011, 10:18 AM
5pointslow's Avatar
crazy to hear on a truck that new. how many kms?
post #5 of 6 (permalink) Old 11-11-2011, 12:19 PM
I would have figured warranty in there somewhere, unless it had over 60k on it in less than two years.
post #6 of 6 (permalink) Old 11-12-2011, 10:23 AM Thread Starter
The dude had racked up over 220k kms of hard towing and driving. Wasn't the poor little motors fault. I got him a used motor with 10 840 kms for $2550. putting it in today.
Box removal xllxll_VIPER_llxllx F-150 1997 to 2003 /04 Heritage Forum 22 05-27-2010 08:05 PM
Panel Removal macs07 F-150 2004 to 2008 Forum 2 01-20-2010 07:45 PM
Oil filter removal ninjabill F-150 2004 to 2008 Forum 15 12-20-2008 12:57 PM
New TSB for 5.4 plug removal. Irish FX4 Sticky Tech/How to Section 2 02-16-2008 04:36 PM
Headlight Removal??? white4by4 F-150 2004 to 2008 Forum 5 02-05-2008 11:40 PM
