Anyone use a Oil Catch on there 5.0 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 13 (permalink) Old 01-28-2012, 09:39 PM Thread Starter
Question Anyone use a Oil Catch on there 5.0
I have a billet on mine and its eye opening to see how much it catches
caperj is offline
post #2 of 13 (permalink) Old 01-29-2012, 10:03 AM
BMac's Avatar
I've seen lots of pics but haven't bothered to as of yet.
Lets see your setup
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #3 of 13 (permalink) Old 01-29-2012, 03:56 PM
Someone was going to do it sooner or later.......
Maybe a little writeup on where you scooped it up and how easy the installation was would be a good addition as well.
Never hurts that's for sure.
If you have problems posting pics, sometimes the easiest thing to do is set up a free Photobucket account and post the IMG code.
Super easy to do.
post #4 of 13 (permalink) Old 02-01-2012, 09:05 PM Thread Starter
Got the part at westernmotorsports, I think the pic will explain how easy it is to install
caperj is offline
post #5 of 13 (permalink) Old 02-01-2012, 09:08 PM Thread Starter
This is about how much you will get after about 1000km
caperj is offline
post #6 of 13 (permalink) Old 02-02-2012, 08:48 AM
RedThunder's Avatar
Will this work with an Ecoboost, or just the 5.0L?
RedThunder is offline
post #7 of 13 (permalink) Old 02-02-2012, 07:09 PM
Can someone explain to me what this oil catch is for. Thanks
parkside is offline
post #8 of 13 (permalink) Old 02-02-2012, 09:53 PM
From what i've read.. the Ecoboost has a catch can already installed.. which is self draining.. but look into it.
I believe it's to keep oil from entering the intake. Sometimes oil can be sucked up thru the pvc. the pipe/tube is there for blow-by. It gets vaccum from the intake to suck out the blow-by gases out of the crank case or the top end. so excess pressure isn't built up to blow out the valve cover gasket.
someone correct me if I'm wrong..
edit..
I figure if it was a requirement.. it would be stock.. I'm sure they have thought of it.
post #9 of 13 (permalink) Old 02-03-2012, 03:45 AM Thread Starter
Oil gets into the intake and actually lowers the octane level of the gas. This is more of a worry in performance engines like the Mustang and it actually gums up in the engine where it is burnt off. I have racing tunes and exhaust and an intake and I like to push the gas so I want to protect my engine as much as possible.
caperj is offline
post #10 of 13 (permalink) Old 02-16-2012, 04:06 PM Thread Starter
Update cleaned up hoses
caperj is offline
Oil changes, who does them and who gets them done? fordtough.ca Truck/SUV Talk 97 11-22-2013 02:47 PM
What Oil? fordtough.ca Gas Engines 28 03-14-2010 09:01 PM
oil fordfan22 F-150 1997 to 2003 /04 Heritage Forum 3 11-15-2009 05:59 PM
