A noob Question? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 03-17-2012, 08:38 AM Thread Starter
Marcin's Avatar
A noob Question?
Hey guys. I see alot of people talking about "tunes". Im new to this so can someone tell me what they are and how they benefit my truck.
Thanks.
What do you do when you're knee deep in mud...get back in your truck
Marcin is offline
post #2 of 4 (permalink) Old 03-17-2012, 08:59 AM
the tune is many factors in how your truck operates.,
the air/fue ratiol, and spark timing. shift points, rev limiter, how soon to shift, shift pressure..
the way I explain it is. ford has tuned the truck your all the uses and needs of the customer
. a programmer or tuner is a device that can adjust the settings or tune of the truck yup be more specific to the customers needs. rather then everyones.
I have a super chips programmer from my last truck. there is different settings I can choose from.
87 mileage- optimized for 87 octane. geared more for fuel economy. not allowed to tow with it.
87 performance-.optimized for 87 octane, performance. firmer shifts. won't shift a soon as mileage. no towing above 2000 lbs
91 performance - optimized for 91 octane, performance, tighter advanced timing, shifting, firmness increased over mileage tube, same as 87 performance tune. no towing above 2000lbs
87 Towing - optimized for 87 octane. modified shift pattern and shift pressures., best towing large loads.
so you see it just makes the vehicle more specific for the drivers needs. pending on your needs at the time you can change it, and revert back to stock when truck has to go into ford for service.
post #3 of 4 (permalink) Old 03-17-2012, 09:06 AM Thread Starter
Marcin's Avatar
Thank you for the detailed explanation. I assume that you can switch tunes on the spot, whenever needed.
What can I expect to pay for a "toy" like that?
Marcin is offline
post #4 of 4 (permalink) Old 03-17-2012, 10:41 AM
A lot of times, the need for a tuner can be linked to changing parts that effect how the vehicle runs.
Best example, and one of the most basic mods, is the addition of a Cold Air Intake, which allows more air to enter into the engine for combustion.
More air with the same amount of fuel means a lean mixture, which is not good for the engine.
A tuner will compensate for that by altering the factory setting and call for more fuel, with the end result of a small gain in horsepower.
I had an XCAL II with three custom tunes packaged in with a CAI for my Mustang, and I think the damage was somewhere in the neighbourhood of $1000...but that was six years ago.
The tuner itself as a stand alone would probably be at least $600.
Noob from PEI Guillotine New Members Introductions 20 03-05-2012 01:48 PM
Noob to the forum johnj New Members Introductions 3 10-18-2011 09:17 PM
noob svukovics New Members Introductions 14 10-19-2008 01:13 PM
Complete NOOB here Slim188 New Members Introductions 18 10-03-2008 01:54 AM
Noob from the BC Interior MtnFordBC New Members Introductions 9 06-29-2008 11:48 PM
