door sills - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 05-20-2012, 04:05 PM Thread Starter
quick98gtp's Avatar
door sills
So prolly the only issue I have with this truck is the poor design of the door sills. Don't like how you can take them off and seee the ground, or how they are basically dirt cathes...anyway was steam cleaning the inside of the truck today, took the door sills off and rust..every hole where the little yellow plugs go had rust around it, poor design, apparently. Anyway just a heads up for anyone who plans on keeping there truck for any period of time, might wanna get a can of rust check ( wich every canadian vehicle owner should already have..lol) and give a shot under there. Tony
quick98gtp is offline
post #2 of 6 (permalink) Old 05-20-2012, 04:14 PM
Pics would help a bunch.
I've got an idea about you're talking about, but in cases like this, a picture really is worth a thousand words.
Same deal for the guy that was crying about the supposed design flaw on his truck that caused it to rust through on the box panel.
I'm not sure what you mean when you say you can take the door sills off and see the ground.
post #3 of 6 (permalink) Old 05-20-2012, 05:19 PM Thread Starter
quick98gtp's Avatar
If you pull your sill covers off, there are plastic nubs that protrude from the bottom of them, that insert into rubber plugs that inturn go into holes that are in the metal, don't have pics as I'm not to keen on pulling them off again till I get replacements, as I just about split the front passenger side in half when removing them...lol
post #4 of 6 (permalink) Old 05-20-2012, 06:26 PM
I was curious enough to go take a look. Here's the door sills in question :
Creep underneath the truck on your back, look up and you can see where the plastic nubs go through the sheet metal... (picture=1000 words lol)
No signs of rust on mine, but it's had annual soakings of Rust Check since new.
I also learned the Raptor's new driveshaft (post-clunk TSB) is a fairly beefy aluminum deal. Nice.
post #5 of 6 (permalink) Old 05-21-2012, 10:30 AM Thread Starter
quick98gtp's Avatar
good pics, and nice drive shaft..lol..But I also had no rust on he underside, It all on the topside, must be were the annual rustproofing doesn't get at.
post #6 of 6 (permalink) Old 05-21-2012, 12:42 PM
Couldn't hurt to take the previously mentioned can of Rust Check, attach the spray tube and shoot some under those sill covers.
For all the time it takes.....
NEED HELP: DOOR HINGES big-papa F-150 Pre-1997 Forum 3 06-01-2010 01:38 AM
Door Hinges JimyB Sticky Tech/How to Section 14 04-08-2010 11:12 PM
need to find Door Sills mrite F-150 1997 to 2003 /04 Heritage Forum 4 02-09-2010 02:10 PM
Covering up the scuffed sills ! flattop414 Care & Detailing 8 09-14-2009 11:47 PM
Gas Door swackly F-150 2004 to 2008 Forum 6 04-04-2009 05:27 PM
