Plug change - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 09-16-2012, 08:04 PM Thread Starter
quick98gtp's Avatar
Plug change
Well finally went through with it. No big suprises. Went with NGK Platinum. Plugs came out like a breeze. The only thing to watch if your going to change these yourself is where the coils are mounted on top of the plug, There is a small "cavity" that collect crazy amounts of debris (rocks, dirt) etc. Used 150 psi air gun and still wouldn't clean it out very well. Used a screwdriver to break apart the piled up dirt and blew it out. A fairly straight forward job. On a side note, the plug size is screwed up. I have three sizes of plug sockets and none of them fit these damn things. I eventually took the little plastic insert out of one and rammed it in a deep 9/16 and worked like a charm. With the new plugs, Superchips tune and the K&N intake this things performs better than I ever thought it could!!
quick98gtp is offline
post #2 of 11 (permalink) Old 09-16-2012, 08:16 PM
Just wondering how many kms are on your truck ? and you have the 5.4 right, my truck is the 4.6 and now has just over 70,000km so I'm wondering should I change my plugs
post #3 of 11 (permalink) Old 09-16-2012, 08:25 PM
Sweet!
Now if you can keep your foot off the floor you'll see some mpg improvements. lol
100k. under normal wear and tear.
there was a problem with the 2 piece plugs on the earlier f150's. It was a recommendation to get them out around 60k so they didn't sieze in there and break.
between 60-100k. i would say..
I think Tony told me he was at 96k.
post #4 of 11 (permalink) Old 09-17-2012, 07:04 AM Thread Starter
quick98gtp's Avatar
Yep, like travis said, 96k. I figured it would go easy but after all the horror stories online about the two peice plug, was in the back of my mind with every plug I broke loose...lol
post #5 of 11 (permalink) Old 09-17-2012, 07:21 PM
So whats a set of those NGK plugs cost ? Think maybe if I ever have extra cash I will buy them and replace mine on a day I have nothing to do.
post #6 of 11 (permalink) Old 09-17-2012, 07:37 PM Thread Starter
quick98gtp's Avatar
My Buddy Josh at wismer's in woodstock hook's me up. His list was 13.95/per paid 60 all in.
post #7 of 11 (permalink) Old 09-18-2012, 08:44 PM
So is that $13.95 a plug ?? Holy crap plugs have gone up in price.
post #8 of 11 (permalink) Old 09-18-2012, 09:54 PM Thread Starter
quick98gtp's Avatar
I think the plugs for this truck are the most expensive i've bought. Could be worse, could be drivin a HEMI V8 with 2 plugs per cylinder.
post #9 of 11 (permalink) Old 09-18-2012, 10:16 PM
I believe O.E.M. plugs are pushing $20. per Grant. Cud be worse, 6.2L run twins per hole!
post #10 of 11 (permalink) Old 09-18-2012, 10:24 PM
Lol suckers. 2 plugs for my 5.0 are $4.98
NEED HELP: Spark Plug Change Toronto Area gbfitz F-150 2004 to 2008 Forum 7 03-02-2011 01:03 PM
spark plug gilligan F-150 1997 to 2003 /04 Heritage Forum 10 12-23-2010 12:47 AM
easy breezy spark plug change :D maplesyrup F-150 2004 to 2008 Forum 2 10-05-2010 08:40 PM
Would this plug in? 4x4truckguy Lighting 6 09-23-2010 08:52 AM
Successful plug change. :) Irish FX4 F-150 2004 to 2008 Forum 3 08-16-2010 09:39 PM
