09' rear springs - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 10-12-2012, 01:26 PM Thread Starter
09' rear springs
Just a question on rear springs. My 09' screw short box has 4 springs. 3 long and one short. I was looking at a 2012 in a parking lot. Same truck, color, etc. It only had 3 long springs. My truck seemed to sit a little higher on the rear but about same in front. What would be the difference.
wrangler is offline
post #2 of 10 (permalink) Old 10-12-2012, 02:35 PM
You can put more weight in yours without sag or bottoming out. The shorter spring at the bottom is a stiffener spring
post #3 of 10 (permalink) Old 10-12-2012, 04:34 PM
KIETH F150's Avatar
Its a screw up from Factory, you should only have 3 springs !!!
Or maybe because you have tow package on your truck.
2012 XLT F150 (Sterling Grey)
Window Visors, Fender Flares
KIETH F150 is offline
post #4 of 10 (permalink) Old 10-12-2012, 04:52 PM Thread Starter
I have the tow package but also the truck I was looking at had tow package but no factory controller. Wonder if when you get tow package with controller you get 4 springs.
wrangler is offline
post #5 of 10 (permalink) Old 10-12-2012, 05:24 PM
KIETH F150's Avatar
Controller is an option offered.
When I ordered my truck, I ordered it with tow package but not with controller. The wire hook-up was under steering coloum so all I had to do was plug the controller in a few months later.
post #6 of 10 (permalink) Old 10-12-2012, 05:33 PM Thread Starter
My 09' had the factory installer already in. Just thought it was odd about the springs.
wrangler is offline
post #7 of 10 (permalink) Old 10-12-2012, 07:02 PM
RedThunder's Avatar
Sounds like someone might have added it along the way. Factory is only 3 springs.
RedThunder is offline
post #8 of 10 (permalink) Old 10-12-2012, 07:40 PM Thread Starter
The Dealership that I picked up this truck also had a 09' f150 with tow max, mine is normal tow package. That tow max had 4 springs like mine.
wrangler is offline
post #9 of 10 (permalink) Old 10-12-2012, 08:14 PM
Cooker's Avatar
My 09 also has 3 long and one short spring, also the built in factory controller
Cooker is offline
post #10 of 10 (permalink) Old 10-12-2012, 09:16 PM Thread Starter
maybe when you get the controller they throw another spring in.
wrangler is offline
Super Springs BluByu1986 Suspension 7 02-03-2014 12:00 PM
help concerning front springs fordfever300 F-150 Pre-1997 Forum 3 04-29-2011 08:48 PM
Front Coil Springs JTSF150 Suspension 1 06-16-2010 05:13 PM
Broken springs Snowdoogie Ranger Forum 6 06-02-2009 09:10 PM
NEED HELP: Super Springs Suspension Sagehill F-150 Pre-1997 Forum 0 09-24-2008 03:45 AM
