Exhaust manifold heat shield - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 11-12-2012, 06:46 PM Thread Starter
I have a 2010 with the 4.6L engine. The truck has 75000kms on it. I was ading wiper fluid into it yesterday and I found the heat shield from the passenger side exhaust manifold has rotted right off! I found it resting on the engine mounts. I get the truck Krowned every year and there is nothing unusual about the use. Has anyone else had this problem? What should I do about it?
msandhar is offline
post #2 of 4 (permalink) Old 11-12-2012, 08:32 PM
Don't think Krown will do much for parts that see a lot of heat, like the exhaust manifold heat shields.
I've never had a problem with any of the heat shields "rotting off" on my F150's, but doesn't mean it can't happen I suppose.
Seeing as you're outside your warranty, (mileage wise), you've got a few choices.
Choice #1 - Do nothing. Probably wouldn't be a bad idea to remove it from the engine mount though, just in case it decides to drop onto the road and bounce it's way from front to back as you're driving.
Choice #2 - Buy a new one and throw it on. I can't imagine heat shields are going to break the bank, but might be a pain in the ass to install.
Choice #3 - Depending on what sort of relationship you have with your dealer (if you have one) , drop by and ask them if they've seen much of the problem.
Who knows....maybe there's a TSB out there, or they might be willing to work toward a solution.
Doesn't cost anything to ask, but I don't think it's anything to get too worked up about.
post #3 of 4 (permalink) Old 11-12-2012, 08:40 PM
Might still be covered under the powertrain warranty.
I don't believe known will touch it because of the heat. Your exhaust manifold would have burnt any known off that would have landed on it anyways.
Check rockauto.com
Maybe a aftermarket alternative is available.
post #4 of 4 (permalink) Old 11-12-2012, 08:53 PM Thread Starter
I wasn't expecting any help from Krown. I only mentioned it.
I will take it to the dealer to see if they are willing to do anything. Mostly I was wondering if it something I need to bother fixing, seeing how the first one didn't stay on there very long.
msandhar is offline
Front Heat Shield SCrew Lariat F-150 2004 to 2008 Forum 1 05-30-2012 03:33 PM
Exhaust Manifold fordx4 F-150 Pre-1997 Forum 12 03-26-2012 05:29 PM
Oil pans and exhaust Manifold bolts ironwerks2 Super Duty Forum 5 11-11-2009 10:16 AM
Broken manifold bolts haywire F-150 2004 to 2008 Forum 4 07-07-2009 06:38 PM
manifold studs LayinHp F-150 1997 to 2003 /04 Heritage Forum 0 02-22-2009 12:22 PM
