wrench sign - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 01-24-2013, 08:54 PM Thread Starter
2MUCH's Avatar
wrench sign
Well today I started the truck with the auto start. As I got to the truck I noticed I had to scrape the windows. As I was doing so the trucks idle slowed down. When I got back in the truck { about 10 min. time lasp} to leave for work the screen on the dash had the big yellow screen with the wrench sing up. I clicked ok so it would go away. But I could not rev the engine and when moving in reverse it was slow backing out of my driveway. When I put it into drive the truck would move very slow and still not let me rev the engine at all. At that point I shut the truck off and started it up right away. No yellow wrench sign and the truck seamed fine. I drove to work parked it outside and drove it home 12 hours later. Still doing fine. I will hook up the SCT tuner tomorrow and see if there is any codes.
Does any of you have any idea's what could be wrong?
2MUCH is offline
post #2 of 10 (permalink) Old 01-24-2013, 09:04 PM
If it wouldn't move very quickly I'd say the truck went in to limp mode on start up. Its odd that you restarted it and it went away.
post #3 of 10 (permalink) Old 01-25-2013, 12:10 AM Thread Starter
2MUCH's Avatar
Thanks for the info. I googled limp mode and looked at this site.
http://www.ehow.com/info_12199368_me...limp-mode.html
And it looks like I got lucky...
Correcting the Condition
If your vehicle is in limp mode, when you get to safety you may be able to shut the vehicle off and wait a few minutes, and then start the vehicle again. Sometimes, this will reset the electronic controls, restoring valid data. You should still have your vehicle checked as soon as possible, because the original fault may still be present. If the vehicle does not reset, you will need to take the vehicle to a repair facility for proper diagnosis and repair.
Read more: What Does It Mean When a Car Goes Into Limp Mode? | eHow.com http://www.ehow.com/info_12199368_me...#ixzz2IxdQcXX4
2MUCH is offline
post #4 of 10 (permalink) Old 01-25-2013, 06:38 AM
RedThunder's Avatar
So did it throw any codes?
RedThunder is offline
post #5 of 10 (permalink) Old 01-25-2013, 09:36 AM
I like Fords Too's Avatar
just throwing a guess to the wind
I don't know about Hamilton but it was 7*F in T-O yesterday , maybe you got a false reading from a sensor - or one the computer thought had to be false
or maybe a frosted up & stuck idle speed motor ??
I like Fords Too is offline
post #6 of 10 (permalink) Old 01-26-2013, 02:22 PM Thread Starter
2MUCH's Avatar
Well no codes were displayed, so I guess things are ok
2MUCH is offline
post #7 of 10 (permalink) Old 01-26-2013, 10:30 PM
RedThunder's Avatar
Not much else you can do then if there's no codes to look up. Keep truckin then.
post #8 of 10 (permalink) Old 01-26-2013, 11:25 PM
ford won't do anything if there isn't a code.
so keep'er truckin!
post #9 of 10 (permalink) Old 01-27-2013, 06:49 AM
Ford may also not do anything if there's a program tune in the computer that isn't factory.
Just sayin' is all, they're a little funny about things like that.
post #10 of 10 (permalink) Old 01-27-2013, 09:37 AM
That's an easy fix, swap it back to stock.
NEED HELP: Wrench Symbol Chipmunk Gas Engines 9 09-01-2012 01:12 AM
Impact Wrench electric or air? romaniuk Tools 23 03-04-2012 06:38 PM
Torque wrench f150phule Tools 20 11-23-2008 01:18 PM
