Turning off door chime - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 04-05-2013, 09:14 PM Thread Starter
TRNRBILT's Avatar
I was trying to clean the inside of my truck out tonight and listen to the radio, but the door chime was going crazy so had to remove the keys from the ignition and work without tunes. Just wondering if anyone has or knows how to turn it off or disconnect it. I have a 2009 f150 XLT.
Thanks James
TRNRBILT is offline
post #2 of 8 (permalink) Old 04-05-2013, 09:20 PM
http://www.youtube.com/watch?v=2L_-0hdDZxc
quick search and this is what i resulted with.
No i have not tried it, nor have i even watched this video. LoL
good luck.
post #3 of 8 (permalink) Old 04-05-2013, 09:24 PM Thread Starter
TRNRBILT's Avatar
I watched it says to cut wire under steering wheel just thought there might have been a key on key off routine you could do to cancel it. Don't really want to cut any wires. I'll keep looking. Thanks
TRNRBILT is offline
post #4 of 8 (permalink) Old 04-06-2013, 05:42 AM
Start listening to Six Feet Under , and turn that shit up. Works for me.
post #5 of 8 (permalink) Old 04-06-2013, 12:25 PM
There's a whole pile of solid death metal that can drown out the door beep. Just let 'er rip and worry about the neighbours later.
In all seriousness though, isn't it just a squat switch on the door? I could be wrong and I haven't looked on my truck but on my old car, I used to just tape over the switch and it would stop.
Sent from my SGH-I747M using Tapatalk 2
Triton Pilot is offline
post #6 of 8 (permalink) Old 04-06-2013, 01:56 PM Thread Starter
TRNRBILT's Avatar
I didn't see the switch like my old trucks have had I think it's built in somehow to the inside of the door. I'll have to pass on the heavy metal though need some haggard or jones or something country on in this truck.
TRNRBILT is offline
post #7 of 8 (permalink) Old 04-08-2013, 09:54 PM
Can't recall off the top of my head, but door chimes may be able to be muted via Programmable Parameters using an IDS. The next time you're in at the dealer ask the tech to have a quick look: Module Programming > Programmable Parameters > Personality (???).
I can check the next time I have an '09 on my rack. 50:50 shot you can shut it up.
^^^ and don't start cutting wires - nothing good will come of that. and the door switch is integrated into the latch.
Varsity Tyler is offline
post #8 of 8 (permalink) Old 04-08-2013, 10:17 PM Thread Starter
TRNRBILT's Avatar
Ok thanks. I thought it was part of the latch. I will see what the dealer says next time I'm near there. I was just going to turn the radio up instead if cut wires.
Thanks again James
TRNRBILT is offline
NEED HELP: shaking when turning at low speed clutch88 F-150 2004 to 2008 Forum 7 02-16-2011 10:30 PM
Door chime issue. f150phule Interior 10 12-21-2010 01:10 AM
Better front axles for turning in 4X4 zedeng Super Duty Forum 3 11-24-2010 02:50 AM
NEED HELP: Turning off DRL Kimmer F-150 2009 to 2014 Forum 3 08-24-2010 05:31 PM
lifted trucks useless ??????????? chime in ppl 2insane Photo and Video Gallery - Members Rides 11 12-24-2007 12:18 PM
